wheel spacers
wheel spacers
Hi all, im new to the forum, Was wondering if you guys can help me out...
Basically im looking for some (10mm rear/8mm front) wheel spacers + extra long nuts.
Where do i purchase some from?
RE: wheel spacers
The TT Shop...sorted me out H and R ones.
RS6 C8 carbon black(merlin)
Panamera Turbo S e hybrid
RS6 C8 launch edition
R8 V10 plus
C7 RS6 PE dynamic pack plus
C7 RS6
Porsche Panamera Turbo
C6 RS6 AVANT
RS4 B7
Golf R32 mk 5
BMW M3 E46
Golf R32 mk 5
Golf GTI mk 5
VW Passat 130d 4 motion
VW bora 150pd
Ford Mondeo Ghia X V6
Ford Focus zetec
Rover 214!!
R8 V10 plus
C7 RS6
C6 RS6 AVANT
RS4 B7
Golf R32 mk 5
BMW M3 E46
Golf R32 mk 5
Golf GTI mk 5
VW bora 150pd
Ford Focus zetec
Rover 214!!
You can purchase some MTM's from me!!
http://forums.quattroworld.com/classifi ... 6093.phtml
Also, with the quattro system, it's best to run same thickness all-around
sonny, what size spacers have you got, 8mm front and 10mm rear??
am thinking this is definitely my next move, need to get those arches filled a bit more! might contact UNIT 20...
anyone gone for 10mm all round??
Daytona Grey TT RS coupe - Stage 1 400bhp+
Misano Red B7 RS4 Saloon (black optics) Milltek Non-Resonated Valved Exhaust SOLD
I couldnt find/buy 8mm hubcentric spacers for the front so fitted 3mm plain ones,any larger than this and your wheel WILL NOT be in contact with you hub,it will just be the bolts alligning the wheel,the inner bore of the alloy is only the correct diameter to mate with the hub approx 5mm into the wheel so if you pack it out by more than that and dont use hubcentric your putting all shear loads through your bolts and not the hub,i wouldnt be a passenger in such a car driven at speed thanks
I have 8mm Front and 10mm Rear (not yet fitted) H&R Hubcentric spacers. size you will need is the 150mm face. the bolts are the 35mm (I think) ones, Virdee no doubt will confirm, I am not at home at the moment so can not confirm.
Few guys are running 8 fronts and 10 rears on here. I think Porky was running 10s all round on his cab.
Yes Hubcentric means it has a lip and the weight is resting on that and not the bolts, and yes this applies to the 8mm, infant all hubcentric spacers, even the 50mm onespsg001 wrote:so does that mean if you can get 8mm hubcentric spacers then its ok because its not just the bolts taking all the force / attaching the wheel to the hub???
There have been horror stories of spacers coming off, and even cheaply made hubcentric ones splitting at the base, Over on a BMW forum it happened to a guy on there who was running a 330ci. they was not made by H&R.
Users browsing this forum: No registered users and 345 guests
