Speedo Problems!!
2.7 V6 30v biturbo - 251bhp
2.7 V6 30v biturbo - 261bhp
tombs
Speedo Problems!!
Post by tombs » Tue Dec 30, 2003 1:19 pm
Has anyone had this problem, sometime ago my speedo stop working for about 1/2, once I had stopped the car and then restarted it it was fine. Yesterday I got into my car and the same thing has happened, everything else seems fine? can anybody shed some light on this? [img]images/graemlins/crazy.gif[/img]
Carps
Re: Speedo Problems!!
Post by Carps » Tue Dec 30, 2003 2:03 pm
Same old answer, really - whack it on VAG-COM and see if it has any DTCs. Regardless, if the speedo is not working may be able to track it down to a sender of instrument fault as VAG-COM also shows speed - if that is still working then I guess you can assume the sender is OK and the cluster is at fault.
You are welcome to borrow my HEX-COM lead if like... Then all you need to do is download the latest VAG-COM and your away
tombs
Post by tombs » Fri Jan 02, 2004 3:10 pm
Thanks Carps, I will take you up on that offer, YHM. [img]images/graemlins/thumbs.gif[/img]
