Warning light... anyone had it before?
klauster
Post by klauster » Fri Mar 05, 2010 10:18 am
Every now and again this warning light comes up, and even though its been into Audi they don't seem to be able to see whats causing it... anyone had it too and any ideas how to put it right?
K
MB2
Post by MB2 » Fri Mar 05, 2010 10:23 am
I think you just need to check your tyre pressures & then reset the TPMS (is in the DIS can get there via the steering wheel) My car had this on the test drive - the tyres were OK but the pressures hadn't been saved properly.
klauster
Post by klauster » Fri Mar 05, 2010 10:25 am
I have checked tyre pressures and tried to store new pressures... still doesn't clear the warning light....
MB2
Post by MB2 » Fri Mar 05, 2010 10:37 am
Perhaps the TPMS has gone wrong then ? I know mine had the exact same light & tyre pressures were OK but when collected car was fixed so I assumed was operator error on the part of the garage but maybe the TPMS had to be fixed ?
klauster
Post by klauster » Fri Mar 05, 2010 11:11 am
Ill get Audi to look at it then, cheers fella
Marcus-RS4
Post by Marcus-RS4 » Fri Mar 05, 2010 12:21 pm
Probably the batteries in them... of which I think they are a sealed unit, so need to be replaced :(
gmk666
Post by gmk666 » Fri Mar 05, 2010 12:29 pm
More importantly - 320 mile range?
Yeah right.
Sims
Post by Sims » Fri Mar 05, 2010 12:33 pm
gmk666 wrote:More importantly - 320 mile range?
Yeah right.
That's impressive, clearly a good one.
kr
Post by kr » Fri Mar 05, 2010 5:14 pm
I was going to say the same for the fuel range, have you got a bigger tank :D
drcarrera
Post by drcarrera » Fri Mar 05, 2010 5:58 pm
I got that when I had a new wheel fitted and the TPMS sensor wasn't working. Not sure if they repalced the sensor or did something else, but they fixed it. I still had to reset the system, and it takes a few miles to synchronise.
Chris
06 Daytona RS4 Avant (B7)
MB2
Post by MB2 » Fri Mar 05, 2010 6:25 pm
I am pretty sure you can disable TPMS either in the DIS or via Vagcom/VCDS so if you are capable of monitoring your own tyre pressures this may be an option rather than buying new sensors ?
PetrolDave
Post by PetrolDave » Fri Mar 05, 2010 8:08 pm
The best way to see what's causing this warning symbol is to see what fault codes the TPMS controller is storing.
It could be as simple as a poor connection to the antenna that receives the signal from the wheel sensoors, or, especially if it's only started recently, it could be one or more of the batteries in the sensors going down. VAG-COM will tell you...
scaghead
Post by scaghead » Sun Mar 07, 2010 7:04 am
surely must be to do with the coking up, eveything else is..
PetrolDave
Post by PetrolDave » Sun Mar 07, 2010 5:33 pm
scaghead wrote:surely must be to do with the coking up, eveything else is..
If that was an attempt at humour, then IMHO it's in very poor taste. I reckon there's enough controversy about coking up without fanning the flames.
SR71
Post by SR71 » Mon Mar 08, 2010 12:54 am
Yeah Dave, but you have to admit, that is funny...
Nice one Scagy!
:biggrin3:
58 C6 RS6 Stage 2+
58 C6 A6 Allroad 2.7 TDi
Previous:
2000 B5 S4 MRC 550 Saloon
2007 B7 RS4 Saloon
1994 S2 Coupe
Users browsing this forum: Google [Bot] and 282 guests
