What to mod to make the RS4 more torquey, for 0-150km range
as title, I dont need the car going like 200km, but I do wish my car can go within 4second from 0-100km/h
Blue_Thunder
- Top Gear
RE: What to mod to make the RS4 more torquey, for 0-150km ra
Exhaust and remap (~420bhp) should get you close.
I'm running 415bhp in my S4 and calculated about 4 seconds 0-60 at Santa Pod last year (using 1/8th mile times/speeds).
I found an MTM chip very torquey, rather than top end rush.
Re: RE: What to mod to make the RS4 more torquey, for 0-150k
well worth having exhaust and remap give you plenty of torqueBlue_Thunder wrote:Exhaust and remap (~420bhp) should get you close.
Porsche Cayman 718S manual SOLD :
2001 black RS4 MRC remap,MRC filter,3" Milltek dp's ,Milltek catback, H&R arbs, Brembo brakes, PSS9`s coilovers, 413 fuel pump, Wagner intercoolers (490bhp. 517 lbs/ft torque )
2008 ultra blue R26 -sold
2003 silver S3 - sold
2002 black A3 1.8T - sold
1988 ford XR2 - dead
RE: Re: RE: What to mod to make the RS4 more torquey, for 0-
actually I suspect my car is MTM chipped by previous owner. How can I tell if its chipped or not? I got the VAG cable and full software. Or do I need to look at the ECU itself? (located on the firewall near the air box?)
B5 RS4 420Hp
MTM is a chip not a remap. Concealed in a box of tricks, wouldn't know it from any other bit of electronic wizzardry.
Re: RE: Re: RE: What to mod to make the RS4 more torquey, fo
It all depends on what you call chip and what you call remapPaulF wrote:MTM is a chip not a remap. Concealed in a box of tricks, wouldn't know it from any other bit of electronic wizzardry.
It is my belief that it is a piece of plastic with some metal/silicon bits on it that has to be attached to the car, as opposed to someone changing the software and not physically altering anything.S2tuner wrote:It all depends on what you call chip and what you call remapPaulF wrote:MTM is a chip not a remap. Concealed in a box of tricks, wouldn't know it from any other bit of electronic wizzardry.To me MTM is a remap.
Don't ask me I'm just the customer you're the man who does it. (Albeit QST in my case).
RE: Re: RE: Re: RE: What to mod to make the RS4 more torquey
Paul, MTM uses encryption sockets for their software, but they are still and regardless doing OEM software modifications, which is exactly what a remap is
You probably mean piggyback controller by "chip", which has become common use for the term since the advent of diesel plugin boxes...
Re: RE: Re: RE: Re: RE: What to mod to make the RS4 more tor
ProbablyS2tuner wrote:Paul, MTM uses encryption sockets for their software, but they are still and regardless doing OEM software modifications, which is exactly what a remap isYou probably mean piggyback controller by "chip", which has become common use for the term since the advent of diesel plugin boxes...
