Bloody typical.....
jd_hants
RE: Re: RE: Re: RE: Bloody typical.....
Post by jd_hants » Sun Feb 21, 2010 4:31 pm
Yes - easy job for YOU!!! lol
It'll keep me out of trouble for the next week or so when I get home from work!!! might have to invest in a small garage heater - BRRRRRR!!!
Would you recommend flushing at all?? Or just clean the strainer and put fresh oil in it???
Golfather
Post by Golfather » Sun Feb 21, 2010 4:47 pm
Unless there's something else I could do?
In order to replace a part, the dealers needs to verify that it is faulty otherwise the warranty company will not pay up.
On a slight boost leak, they usually cannot see this visually so need to pressure test the IC.
They will most probably not have the equipment in the workshop to do this but if you persist, they will outsource the work as long as you agree to pay if they do not find a fault.
You can also get MRC to fax off confirmation of the leak to the dealer to further strengthen your case.
Post by bam_bam » Sun Feb 21, 2010 4:50 pm
Will do and many thanks for the advice.
grizz
Post by grizz » Sun Feb 21, 2010 5:11 pm
I just fit a new oil pump and pick up pipe , Clean the sump as it'll be full of black sludge..
Unit 20
0151 3366888
Post by Shoppinit » Sun Feb 21, 2010 5:57 pm
jd_hants wrote:Well thats 2 things. I'm bracing myself for the 3rd!!!! :-O
Have you been going round kicking black cats and walking under ladders recently?
I hope the damage isn't terminal in your 1.8T.
jd_hants
Post by jd_hants » Sun Feb 21, 2010 6:28 pm
And it was only last week, it sailed through its MOT. Guess the sludge was just building up and finally blocked the pipe.
Grizz: You would fit a new pump aswell???? Is that likely to be damaged? Or just needs a bloody good clean? I suppose trying to pump sludge is not to healthy for it.
kwack
Post by kwack » Sun Feb 21, 2010 7:52 pm
mine was the avus silver one at camberley which had loads done under warranty but which is now broke down
paddybrenn
Post by paddybrenn » Sun Feb 21, 2010 7:53 pm
A mate had his Z4 M in and they gave him an Aston Vantage after he complained they didn't have anything like for like....
Re: RE: Re: RE: Re: RE: Bloody typical.....
Post by bam_bam » Sun Feb 21, 2010 11:15 pm
paddybrenn wrote:A mate had his Z4 M in and they gave him an Aston Vantage after he complained they didn't have anything like for like....
Ha! Did he return it with ANY depth left on the rear rubber?
Awesome, I'd be breaking stuff on the Z4M every other day to get back into the Vantage.
RE: Re: RE: Re: RE: Re: RE: Bloody typical.....
Post by HYFR » Mon Feb 22, 2010 12:00 am
JD - had the same issue on my old B6 1.8T
Bam Bam- one word, WARRANTY !! :kissmyrings:
jd_hants
Post by jd_hants » Mon Feb 22, 2010 7:47 am
David - yes same car B6 1.8T Sport. Did you fix yourself?
Read the Haynes manual (better than nothing) and seems straightforward except it mentions Audi recommends replacing the 'intermediate plate' and using some kind of sealant. I assume its just normal gasket sealant???? Every new job is a learning curve!!
Post by Shoppinit » Mon Feb 22, 2010 9:34 am
Looks like a dead easy job to change the oil pump. Messy, but easy :)
If it's tried to pump sludge, maybe you should flush the system? Something to unclot the oil channels since some of them are quite small? I don't know if that even exists. Warfarin for cars :)
jd_hants
Post by jd_hants » Mon Feb 22, 2010 10:05 am
Probably a lot easier on ramps rather than axle stands!
Yes, I was unsure about flushing. Some people say flush it a few times and then use cheap oil for a bit, drain, reflush and repeat until its free of sludge/contaminants. and others say it will dislodge dried sludge and might cause further problems.
Personally, I think I'll flush a few times. I'd rather try to clean it as well as I can. But I guess I had better clean/replace the strainer first as its not going to pump the flushing agent around.
Post by Shoppinit » Mon Feb 22, 2010 10:06 am
What I would personally do, is first clean the strainer, but loads of flushing agents in and see if the engine runs. No point spending lots of money if it's started to seize.
jd_hants
Post by jd_hants » Mon Feb 22, 2010 10:57 am
Just looked on VAGCAT and seen there is no sump gasket, just silicone sealant. Any idea if its special stuff or can get it from Halfords????
Also, according to Haynes, I need an engine hoist?!?!?! Is this to take the weight of the engine while the subframe is removed?? This is sounding more like I need to take it to a garage?!?!?!
Users browsing this forum: No registered users and 205 guests
