against this one from Arthur's 26k engine - maybe US engines/fuel are different?SR71 wrote:Just to remind ourselves of what we're potentially looking at:
in a race car tuned to the limit, it may help perfromance a few %, mayrsierra wrote:Arthur, Why do engine tuners spend endless hours on a flowbench trying to extract the most flow from a cylinder head?
Also you insist that you have proven that carbon build up has no effect on performance. I have read your posts here and on on other sites and yet to see any conclusive evidence that supports your claim. Maybe you can summarize the data that supports your claim. I am talking real world performance data not theory.
The other thing I am trying to understand is your motivation. You are clearly obsessed with defending Audi, and even mention that it would be very difficult to win a lawsuit against them.
Are you working for Audi in some way?
yes it will, pumping losses will increase slightly to overcome the additional DP required to flow the Q of air, but rest assured, the pump will pump the same volume of air...SimonC wrote:I do not believe that an excessive build-up of debris on the inlet valves of this engine will have no effect on engine performance when the throttle is wide open and the engine is operating at maximum speed. My initial post in this thread was to question a post stating otherwise. The engine is attempting to draw the same volume of air through a smaller opening in the same amount of time. This will result in a slightly higher load on the engine and a slight reduction in the density of the air at the point when the cylinder is sealed.
The interweb is littered with information and maths proving both sides of this debate.
Maths in engineering requires testing because there is too much to consider, otherwise Toyota wouldn't be where they are now. Without the specific data, dimensions, flow-rates, etc which I'm sure only the boffins at Audi have access to these sums cannot be completed - they're just formulae, theory and presumption.
It is widely known that improving the ability of a naturally aspirated engine to breathe through subtle reductions in flow restrictions around the valves improves engine performance and I'm sure the people at Cosworth or any other such company would consider the removal of these deposits as essential for high flow at high engine speed.
I don't wish to malign an excellent car any more, I'd just like to see the manufacturer accept and eliminate this issue. And that's not going to happen if the owners are led to believe that the issue is irrelevant.
again, personal character assassinationsims wrote: With the engineering skill you have, you have failed to convince other engineers, those who are not intimidated by you and those with common sense.
However, you have convinced me about this - that your conduct is threatening; abusive; harassing; vulgar; obscene; offensive; objectionable as anyone who reads your posts will confirm. To use words like whore, choads, loser, whiner etc devalues any contribution you do make. Does anyone here know what choad means?
I am not the 1st on these forums to suffer your insults, and I am sure your trait will forever remain whereas the carbon build up issue will not.
Have a good day.
yes it was a jokeBlingBling wrote:This is a joke post right? In the 10 minutes between your posts you managed to remove, inspect and re-install the intake manifold.......! That truly defies all logic and physicsArthurPE wrote:ok, let me catch my breath....
between my last post and this one...
I removed the manifold
took pics
reinstalled
whew!
26k miles, never cleaned
Also, I have seen that picture posted on another forum by a member who actually had their valves cleaned after a build up. It will come to me soon which one
Nonsense. I only have 200 posts (including some with light banter, but not offensive,derogatory, rude) - others can check them out. You, Sir, have a reputation for wildly lashing out at people who disagree with you and that is a big issue for you to deal with.ArthurPE wrote:sims wrote: With the engineering skill you have, you have failed to convince other engineers, those who are not intimidated by you and those with common sense.
Have a good day.With respect, your language has been awful. and unbecoming for this forum. Without any foundation and based entirely on your prejudice, you have accused me of lying. I shall await your apology. And in the meantime, I hope you will not inflict your foul language on others.ArthurPE wrote: again, personal character assassination
kettle meet pot![]()
ArthurPE wrote: and I'm not the first to suffer yours...
glass houses and all...you need to check yourself and stop worrying about me and deposits...you have bigger issues to deal with...
I agree, nonsense...sims wrote: Nonsense. I only have 200 posts (including some with light banter, but not offensive,derogatory, rude) - others can check them out. You, Sir, have a reputation for wildly lashing out at people who disagree with you and that is a big issue for you to deal with.
Users browsing this forum: Google Adsense [Bot] and 179 guests
