Which oil for the 6? 30, 40 or 60?
Post by Shoppinit » Fri Feb 19, 2010 11:14 pm
I'm trying to get my head around the different oil grades. Not interested in brands.
Manual says 5w40 VW505.01
Audi put in 5w30 VW507.00 last time I had an oil change
Some people swear by 10w60
60 sounds awfully thick to me. I used to put 50 in my mk3 escort to stop it smoking :shock:
Am I OK on 5w30?
GarethRS
RE: Which oil for the 6? 30, 40 or 60?
Post by GarethRS » Sat Feb 20, 2010 12:19 am
I do my own oil changes and researched this a while back.
I chose Mobile Edge 5w/30. Two reasons;
It was recomended on here and it is available over the shelf from Halfords.
Hope this helps
skyegtb
Re: Which oil for the 6? 30, 40 or 60?
Post by skyegtb » Sat Feb 20, 2010 1:41 am
I also do my own oil changes and use 5w40 VW505.01 simply because this is the manufacturers recommended oil for the car.
2003 RS6 MTM 568
Post by Shoppinit » Sat Feb 20, 2010 9:17 am
skyegtb wrote:I also do my own oil changes and use 5w40 VW505.01 simply because this is the manufacturers recommended oil for the car.
This logic appeals to me, but I believe that the 505.01 (some of which is 5w30, but most is 5w40) has been superceded by the 507.00 which is all 5w30. This didn't exist when the original recommendation was made.
skyegtb
Post by skyegtb » Sat Feb 20, 2010 9:21 am
In that case it must be safe to assume that the new 507.00 must be compatible, if not better than the older 505.01 spec oil? Personally I will be sticking to the 505.01 for at least the next 3 oil changes as I recently bought a 25 litre drum of the stuff!
2003 RS6 MTM 568
RS6Steve
RE: Re: Which oil for the 6? 30, 40 or 60?
Post by RS6Steve » Sat Feb 20, 2010 9:23 am
Got my oil from Audi as per the manual £25.
Steve
RS6 gone, R32 gone, M3 gone, Porsche Cayenne Turbo gone, Boring A6 saloon gone, Boring A6 Avant going in 5 weeks :D . Maybe RS5 or S5 Hatchback to come...
tartan_rob
Post by tartan_rob » Sat Feb 20, 2010 5:50 pm
I use race oil. Motul 0w20 300v high rev.
2017 Kawasaki Z1000
2014 RS6
2014 S1
Post by Shoppinit » Sat Feb 20, 2010 5:55 pm
Yes, but you are insaaaaane :)
Why 20? What's the idea behind it? Not being critical, just interested to know.
mtech114
Post by mtech114 » Sun Mar 07, 2010 10:55 pm
If you want your engine to last platinum 5w40 fully synthetic can not be beaten!! The 40 indicates the thicker viscosity at opperating temperature! The specially formulated 1.9 tdi pump Duse oil was originally recommend, from day 1! Pd cam lobes were subject to higher opperating loads/increased friction! So it was advised for use in the rs6 engine to ruduce cam lobe wear!!! Platinum 5w40 is a pd oil! 0w30 is like tap water! Ok to use but I'd pass!
mtech114
Post by mtech114 » Sun Mar 07, 2010 10:56 pm
If you want your engine to last platinum 5w40 fully synthetic can not be beaten!! The 40 indicates the thicker viscosity at opperating temperature! The specially formulated 1.9 tdi pump Duse oil was originally recommend, from day 1! Pd cam lobes were subject to higher opperating loads/increased friction! So it was advised for use in the rs6 engine to reduce cam lobe wear!!! Platinum 5w40 is a pd oil! 0w30 is like tap water! Ok to use but I'd pass!
Users browsing this forum: philS2 and 89 guests
