Is there a sensor or switch for this somewhere that anyone knows of please?
car doesn`t know the drivers door??
markademus
MountainMutant
RE: car doesn`t know the drivers door??
Sorry - I'm probably being thick - but what exactly doesn't it know?
Do you mean when you press the key fob? Do you mean that the "door open" indicator is on?
Is the door there????
The door sensor circuit is located within the door lock itself.
More often than not, you can take these apart and clean the contacts to get them working again.
I know in VW golf's the door control module fails and it means the car doesn't recognise the drivers door is open. Also linked to the 'lights on buzzer' so if that doesn't sound if you leave your lights on then perhaps its also an audi problem too.
tartan_rob
The door lock contains the contact switch. Strip and clean or replace....
2017 Kawasaki Z1000
2014 RS6
2014 S1
2014 RS6
2014 S1
markademus
yeah sorry was a big vague on the the decription, when the ignition and the door is open the dis doesn`t pick it up.
thanks
will do this tomorrow to see.The door sensor circuit is located within the door lock itself.
thanks
Users browsing this forum: Majestic-12 [Bot] and 96 guests
