Any help greatly appreciated gents
Recently had a steady engine warning light appear, turned out to be hall sender was duff. had it changed today, fault codes cleared, mechanic took it for a drive and all looked well, no light and no fault codes.
About 10 miles down the road the engine light starting flashing then went out. a couple of miles later and it starting flashing again and then went out. popped out a little later on and the same problem. cant get access to vagcom again til wednesday. any ideas?
whats the significance of the flashing rather than the steady light?
Thanks in advance for any answers.
Flashing Engine Light?
B5 RS4 AVUS SILVER
- mattykerby01
RE: Flashing Engine Light?
Could be a misfire ?
I had this on my car and turned out to be a knackered coil pack on cylinder 4
Post VAGCOM faults when you get plugged in.
