Request for gents with a data logger:
ArthurPE
Post by ArthurPE » Tue Jan 19, 2010 5:13 pm
but on the whole:
average ~7.9
throwing a few 10'th for error and atm conditions ~8.2
still better than rated (8.4) and damn close to the 8 flat average of 4 mags full out runs using all gears!
I would like to see about 5 more cars in the sampling...
also whether the cars have been cleaned...
Gumball0r
Post by Gumball0r » Fri Jan 22, 2010 3:33 am
Just did another three runs. -2 degrees, damp road, TC off, flat road, 1/2 tank of 99 V-power.
7,2
7,1
7,2
Car ran better then ever! Scared the <beep> out me when I later stepped on it in 2nd, and it went sideways :O
P_G
Post by P_G » Fri Jan 22, 2010 12:58 pm
Is yours modified in any way Gumball?
Gumball0r
Post by Gumball0r » Fri Jan 22, 2010 1:18 pm
No, therefore these times surprised me. 1 second faster than magazines test results seems odd, but it may have to do with the cool air. Maybe I should visit my local dyno to see how it does.
aidanjaye
Post by aidanjaye » Fri Jan 22, 2010 3:19 pm
Gumball - with those time, reckon you car might have a bit more poke than a normal RS4. FYI - nailing it in 2nd in mine sometimes has the TC light flicker but doesn't lose traction like you said.
ArthurPE
Post by ArthurPE » Fri Jan 22, 2010 10:46 pm
the cold air may add 1/2 sec or so depending on atm press and humidity...
some of my times :
set 2
25 F
fuel 3/4
passenger yes
7.7
7.3
7.4
ArthurPE
Post by ArthurPE » Fri Jan 22, 2010 10:57 pm
Gumball0r wrote:Just did another three runs. -2 degrees, damp road, TC off, flat road, 1/2 tank of 99 V-power.
7,2
7,1
7,2
fast, very fast
added to the data base
scaghead
Post by scaghead » Sat Jan 23, 2010 7:13 am
7,2
7,1
7,2
you sure fella... i will give this a go in the next couple of weeks...if she starts, been in the garage for 2 months :)
JackS4
Post by JackS4 » Mon Jan 25, 2010 9:18 am
Got to do 2 runs (couldn't manage a 3rd) Me, wife, 2 kids + weekly shop in boot with 3/4 tank. Dry road 6c on slight up incline - MRC button on :
7.4
7.2
J
ArthurPE
Post by ArthurPE » Tue Jan 26, 2010 1:04 am
JackS4 wrote:Got to do 2 runs (couldn't manage a 3rd) Me, wife, 2 kids + weekly shop in boot with 3/4 tank. Dry road 6c on slight up incline - MRC button on :
7.4
7.2
J
very fast....with load and incline
valves cleaned?
sedan?
mileage?
aidanjaye
Post by aidanjaye » Tue Jan 26, 2010 2:29 am
If bods are getting 7 secs with standard cars then I'm a green haired seagull.
If your getting 8 secs then thats fast - the difference between 7 and 8 secs is a fast car and a very fast car.
JackS4
Post by JackS4 » Tue Jan 26, 2010 8:59 am
7.4
7.2
J
valves cleaned?
sedan?
mileage?
Full MRC treatment (3k miles ago) with valve clean and 100cel cats, saloon, mileage 27k.
J
SR71
Post by SR71 » Tue Jan 26, 2010 12:35 pm
So what are we saying here?
Aside from Gumball's car, whose history we're not sure of, and the odd "low" time which lies somewhere oustide the standard deviation, all the "cleaned" cars are substantially faster....
Even AthurPE is asking if the valves have been cleaned?
Does it, or does it not make a difference?
Or are there too many variables that are not being controlled in these tests?
58 C6 RS6 Stage 2+
58 C6 A6 Allroad 2.7 TDi
Previous:
2000 B5 S4 MRC 550 Saloon
2007 B7 RS4 Saloon
1994 S2 Coupe
P_G
Post by P_G » Tue Jan 26, 2010 4:09 pm
It would appear at this time there are too few cars in the relevant categories, saloon vs Avant vs cab, OEM or modified (and if modified just air filter, remap, Milltek cat back / 100 / 200 cell), valves cleaned or not not to mention temperature weight with fuel etc to get an accurate picture. With the above there must be at least 200 permutations without taking into account the latter 2 that will affect timing and therefore performance.
Worthwhile collating though to see what people can do and what is achievable.
sonny
Post by sonny » Tue Jan 26, 2010 5:52 pm
Agree we should make a new thread stating in a logical order of those mods, PAX on board etc, and collate all the times, would be worth while reading, Aurther are you taking the info from here and adding it to your data base and then will you put up the final?
So heading would be along the lines off SALOON/CAB/AVANT, YEAR, MILEAGE, LAST SERVICED, FUEL, PASSENGERS, WEIGHT OF DRIVER, ATMOSPERICS....The list could go on, but yo get the drift, Maybe even add it as a sticky.
It also shows that some ppl have been using different methods of recording times, stop clocks, digi timers and the data logger, some of these much has a -/+ factor.
