Request for gents with a data logger:
Billy
Post by Billy » Tue Jan 19, 2010 12:00 am
pippyrips wrote: That's one quick car you have Billy :D
That it is mate, you should know :)
ArthurPE wrote:
much better than stock 8.4
actually better than all gears at 8 flat!
even after adjusting for temp ~7.9
how many miles, were the valves ever cleaned?
if the numbers are ~accurate, can anyone say the car is down on power?
or that cleaning the valves make it faster?
Pippyrips will correct me if I'm wrong, but I believe the valves were cleaned at roughly 22500 miles
The car has done about 5000 miles since.
Gumball0r
Post by Gumball0r » Tue Jan 19, 2010 12:03 am
According to this http://www.rs246.com/index.php?name=PNp ... torder=asc the car is modded.
My car has done 30k miles. My times do seem strange, though I hope the onboard computer doesn't lie. If I remember it, I'll time some runs tomorrow to see if I can repeat it. I have no mods and no cleaned valves.
ArthurPE
Post by ArthurPE » Tue Jan 19, 2010 12:13 am
I'm putting a spreadsheet togther...I know others have done this, if so, kindly post (or cut and paste from the deposit thread)
Billy
Post by Billy » Tue Jan 19, 2010 12:20 am
Yes the car is modded, it's Pippyrips old car.
ArthurPE
Post by ArthurPE » Tue Jan 19, 2010 12:32 am
ok,here's the spread sheet, please review and let me know what I've missed
also, the more the merrier, either more runs or new guys, or both :D
new sheet, added 'cleaned' for valves
3k to 8k runs.xls
(14.5 KiB) Downloaded 81 times
Gumball0r
Post by Gumball0r » Tue Jan 19, 2010 12:41 am
You've written my times incorrectly. My runs were:
7,6
7,8
7,7
7,7
Averaging 7,7 seconds.
ArthurPE
Post by ArthurPE » Tue Jan 19, 2010 12:55 am
Gumball0r wrote:You've written my times incorrectly. My runs were:
7,6
7,8
7,7
7,7
corrected, thnx
ArthurPE
Post by ArthurPE » Tue Jan 19, 2010 1:06 am
ok, added some statistical crunching
3k to 8k runs.xls
(15.5 KiB) Downloaded 79 times
SR71
Post by SR71 » Tue Jan 19, 2010 10:19 am
Without wishing to cast aspersions on anyones time...
How are people measuring these times?
And what are we measuring? Starting in 3rd at 3000rpm and "stepping on it" or starting at 2000rpm and then measuring the 3000-8000 interval?
I'd suggest the only reliable way is using VAGCOM as opposed to the Mark 1 eyeball...
If not, at least add a +/- 0.3 delta...
I seem to remember a while ago someone claiming a 4 sec 0-60 at which point it transpired they were using the speedo and onboard lap timer to measure the time...
My $0.02.
58 C6 RS6 Stage 2+
58 C6 A6 Allroad 2.7 TDi
Previous:
2000 B5 S4 MRC 550 Saloon
2007 B7 RS4 Saloon
1994 S2 Coupe
pippyrips
Post by pippyrips » Tue Jan 19, 2010 10:26 am
Good point, well made.
Without electronic equipment these results have just as many, if not more variables than rolling roads, and we all know the fuss they have caused!
Billy
Post by Billy » Tue Jan 19, 2010 11:02 am
I used the onboard timer and started at 2000rpm in 3rd. Foot to floor and then measured 3000-8000.
I know it won't be 100% accurate, but was just a bit of fun.
I already know this car has no power issues.
SR71
Post by SR71 » Tue Jan 19, 2010 11:35 am
We know your car is quick Billy!
But we might as well try and get the community
to collate the best data possible.
58 C6 RS6 Stage 2+
Previous:
2007 B7 RS4 Saloon
1994 S2 Coupe
Post by HYFR » Tue Jan 19, 2010 11:41 am
if we're talking 0.something of a second error, is that something we can really notice !?
my car is fecking fast whether its putting out 414bhp or 214bhp
Gumball0r
Post by Gumball0r » Tue Jan 19, 2010 2:52 pm
It may not be 100% correct numbers, but knowing that my car is close to being as fast as Billy's (Which dyno'ed 431 hp), I don't have to give a <beep> about carbon build up or such things.
ArthurPE
Post by ArthurPE » Tue Jan 19, 2010 4:01 pm
imo the results are accurate to a sufficient degree, consider:
-no gear change is required, ie, no variable
-the tach is dead accurate, and if it isn't, it's error is cancelled on either end
-mutliple runs averaged negate error
-the timer is dead accurate (within 0.05 sec)
-the timer is easy to use, ie, no shifting of hands for the entire run
-as usual with manual timing (it was used in the Olympics) error(s) cancel, -if you start a bit late, you stop a bit late, the usual scenario...
I would venture the average accuarcy of any given set of times are +/- 0.1 sec, not accounting for atm conditions...
