rear brake discs
rol
rear brake discs
Post by rol » Wed Jan 13, 2010 8:37 pm
Why are te rear discs more expensive?
R.
ecain63
RE: rear brake discs
Post by ecain63 » Thu Jan 14, 2010 8:20 am
Because its Audi, most likely. Nothing should be assumed when pricing audi spares.
Phone Grizz at Unit 20. He'll sort you out.
Now Sold!
'03 Daytona Grey RS6 Avant.
275 Vreds.
MRC custom map with TCU.
Miltek Resonated.
Hi Flow filters.
19" 'Plus' (Grey) rims.
CliveH
Post by CliveH » Thu Jan 14, 2010 8:28 am
Surely not??! They're smaller to start with :shock:
But are there any alternatives?
Clive
ecain63
Post by ecain63 » Thu Jan 14, 2010 8:33 am
No alternatives to OEM ones.
Now Sold!
275 Vreds.
Miltek Resonated.
Hi Flow filters.
CliveH
Post by CliveH » Thu Jan 14, 2010 8:43 am
Nothing from the Phaeton range?
Clive
Golffather
Re: rear brake discs
Post by Golffather » Thu Jan 14, 2010 10:10 am
rol wrote:Why are te rear discs more expensive?
R.
I assume you're comparing with prices for the fronts, in which case you're mistaken, the rears are cheaper. However, non-drilled are considerably cheaper than drilled for fronts and rears.
Re: RE: rear brake discs
Post by HYFR » Thu Jan 14, 2010 10:38 am
CliveH wrote:Nothing from the Phaeton range?
yes Phaeton rears work, had them on my old RS 6. £75 a disc direct from VW
Daveperc
RE: Re: rear brake discs
Post by Daveperc » Thu Jan 14, 2010 10:39 am
The Phaeton rears (undrilled) are cheaper (why???) and fit straight in I believe. Check with Grizz or MRC
Dave
Post by HYFR » Thu Jan 14, 2010 11:01 am
not a straight fit, needs a small spacer on the bolts I believe
Grizz fit mine
rol
Post by rol » Thu Jan 14, 2010 11:03 am
I have just bought non drilled front discs 315 pounds for the pair delivered but got quoted 500pounds for the rear pair of the same company.
R.
Daveperc
Post by Daveperc » Thu Jan 14, 2010 11:11 am
Front price sounds about right, but I suspect that dealer has quoted for two pairs on rear.
Try DSGWagen in Doncaster - they are usually pretty low cost, or of course give Grizz or MRC a call.
I have a feeling the Phaeton ones were really cheap (?£68/disk?) so even with the extra cost of a spacer or two, may be the way to go. DK - how much was the whole set up??
Dave
Post by HYFR » Thu Jan 14, 2010 11:56 am
it didnt cost any more for a spacer, im not talking about a spacer you'd put on a wheel, i think it was a spacer for the bolt...
they cost me £75 inc vat each from VW grizz just charged labour to fit
Golffather
Post by Golffather » Thu Jan 14, 2010 11:59 am
The RS6 non-drilled discs aren't that much more than the Phaeton rears IIRC
Daveperc
Post by Daveperc » Thu Jan 14, 2010 12:00 pm
Spacer as in washer (to make bolt shorter) or sleeve (to make bolt bigger)??
Certainly sounds like the way to go - though they aren't drilled of course
Dave
Re: RE: Re: rear brake discs
Post by HYFR » Thu Jan 14, 2010 12:14 pm
Daveperc wrote:Spacer as in washer (to make bolt shorter) or sleeve (to make bolt bigger)??
Dave
yes thats the one, though not sure which (prob washer)
they can prob be had cheaper from non VW dealer, I tried GSF at the time but they were useless
Users browsing this forum: Majestic-12 [Bot] and 219 guests
