Sat nav in DIS
JonW
Sat nav in DIS
Post by JonW » Thu Jan 07, 2010 11:23 am
Can anyone suggest why the sat nav info will not display in the DIS on my Plus?
Thanks,
Jon
RE: Sat nav in DIS
Post by Shoppinit » Thu Jan 07, 2010 11:42 am
Your TCM/Canbus module may be dead. Do your steering wheel buttons work? What about the menu button by the handbrake?
RE: Sat nav in DIS
Post by HYFR » Thu Jan 07, 2010 12:53 pm
do the sat nav buttons on the unit light up when you switch your lights on
RE: Sat nav in DIS
Post by Shoppinit » Thu Jan 07, 2010 1:33 pm
Can you rub your tummy and pat your head at the same time?
batty
RE: Sat nav in DIS
Post by batty » Thu Jan 07, 2010 1:49 pm
have you tried toggling the display. the button at the base of the RH stalk toggles between computer, nav and no-display.
from memory, the default from startup is to display the nav info...
c5 RS6 plus in silver
JonW
Re: RE: Sat nav in DIS
Post by JonW » Thu Jan 07, 2010 3:35 pm
Thanks for the replies.
No buttons on wheel. Menu button works fine.
Yes; will that help? :wink:
Not sure which lights you mean?
Yes, just toggles between comp and no-display.
RE: Re: RE: Sat nav in DIS
Post by Shoppinit » Thu Jan 07, 2010 3:41 pm
I presume you've actually programmed a destination in?
Post by Shoppinit » Thu Jan 07, 2010 3:44 pm
Is it RNS-D or E?
JonW
Post by JonW » Thu Jan 07, 2010 3:49 pm
RNS-E and, yes, with destination set!
Post by Shoppinit » Thu Jan 07, 2010 4:00 pm
Is it a retrofit? Can't remember if all plusses had E. Have you got a vagcom?
Have you got the security code for the radio? You could try a reset. You could disconnect the battery for a few minutes and reconnect it. This is recommended for suspected trouble with the TMC/Canbus module.
JonW
Post by JonW » Thu Jan 07, 2010 4:10 pm
Standard on plus.
No vagcom.
Will have code somewhere so I will have to root it out and try the reset.
JonW
Post by JonW » Thu Jan 07, 2010 8:20 pm
Reset hasn't helped. Any other thoughts or will I have to resort to £s at the stealers?
batty
Post by batty » Thu Jan 07, 2010 8:39 pm
mine is a plus, and yes RNS-E is std on plus's. mine shows nav on the DIS, even if there is no destination set.
In fact it's a bit of a pain, as have to toggle twice to get fuel data every time from startup....
but sorry - don't know what your fault could be.
andyt
Post by andyt » Thu Jan 07, 2010 9:59 pm
What he means is that when you put your lights on, all the buttons on the dash light up red. This should include all the buttons on the RNS-E too, which it does by responding to a message on the canbus. If the canbus is faulty to/from the RNS-E (so that messages don't get to the DIS), then the message to turn the lights on may well not get through too. I guess that's what he's thinking.
JonW
Post by JonW » Fri Jan 08, 2010 9:45 am
I see; yes, all the buttons on the unit and dash come on.
Users browsing this forum: asgor and 74 guests
