Hi all,
Now when I bought the RS last year I wasn't really thinking about the environment but mine, over the last few days has turned in a milk float..
I'm assuming that it's down the cold weather but was wondering if anyone else is having this, I'm getting a constant loud whining noise - does it both in and out of drive. Is this the steering pump?.. Is this normal in cold weather or do I need to be checking something out?..
Any thoughts would be appreciated.. Thanks..
Electric RS6
Electric RS6
C5 RS6 - Mugello Blue - H&R
Quote: “We hit 140 and you were still pulling away like we were stood stillâ€
RE: Electric RS6
Do not sound good get it checked right away,
Bobby
Bobby
RS6 Saloon 04- Non Res Milltek- Forge dump valves- Led Rear Lights- Ally steering paddles- 20" Rotors- RNS-E- I.G Air Fiters,
Re: RE: Electric RS6
Update - Had a reply from Grizz on Audisrs.com to check the power steering fluid..rob8457 wrote:Do not sound good get it checked right away,
Bobby
RE: Re: RE: Electric RS6
The gearbox will squeal if the ATF is low as the pump cavitates (like the power steering pump will cavitate if the fluid is low).
Re: RE: Re: RE: Electric RS6
Thanks Shoppinit, is there a way to check the ATF fluid level or is it a case of changing it to make sure? (the box is under a year old and the gear change is okay) was planning to do annually anyway but it's not due until April.Shoppinit wrote:The gearbox will squeal if the ATF is low as the pump cavitates (like the power steering pump will cavitate if the fluid is low).
RE: Re: RE: Re: RE: Electric RS6
Yup, power steering fluid well low
just below min.. what's the best was to check for leaks / commen places that leak?!.. ta
Users browsing this forum: steve2003rs6 and 72 guests
