drivers door seized up !!!
philroach
Post by philroach » Mon Jan 04, 2010 8:50 am
all other doors are fine ,, but drivers door is stuck solid
has happened before , but normally give the window frame a bit of a push , and the frozen bits come apart
even the door handle stayed 'out' when i pulled it
had to lean over the back seat to fire the beast up this morning , 5 minutes later , car is all warm , but i have had to scramble across the passenger seat to get in , and even a 15 stone 'soft' shoulder barge couldnt shift the door !!!
handles both move , locking knob does pop up with handle or plipper
any thoughts ???? or solutions please ????
Phil
DRC
RE: drivers door seized up !!!
Post by DRC » Mon Jan 04, 2010 10:18 am
Are you absolutely sure that the lock operated?
Violence is the answer when the door is just frozen into its frame, but if the lock sticks there is not that much that can be done until it warms up, which takes ages even with the heater full on.
RS6Steve
Post by RS6Steve » Mon Jan 04, 2010 11:04 am
Warm water does the Job well
Steve
RS6 gone, R32 gone, M3 gone, Porsche Cayenne Turbo gone, Boring A6 saloon gone, Boring A6 Avant going in 5 weeks :D . Maybe RS5 or S5 Hatchback to come...
philroach
Post by philroach » Mon Jan 04, 2010 12:21 pm
hoorah !!! door has finally opened , ..... , but on the downside , it wont shut now !!!!
Obviously it is freezing inside the door , any sprays recommended , silicone or otherwise ??
Now : XFR Jag 5.0 Supercharged
Used to have : C5 Daytona Avant , silver leather , carbon inserts ; RNSE, TV in motion, Bluetooth , well filled SD card slots ; PSS9's ; Hotchkiss ARB's ; Miltek cat back res ; Wagner intercoolers ; Phaeton brake ducts ; forge DV's ;
spurtle
Post by spurtle » Mon Jan 04, 2010 7:34 pm
On all my other Audis, holding the driver door handle out for a few seconds activates a lock heater - de-ices the lock pretty quickly. Haven't tried it on the '6 though.
RS6 Avant (C5), Daytona grey
Gone but not forgotten: S4 Avant (B5)
philroach
Post by philroach » Mon Jan 04, 2010 7:45 pm
blimey , never heard of that one , will give it a try tomorrow
still wonder what can be sprayed / rubbed on door seals, ( not vaseline !! ) , and in to lock , to stop it happening again???
coullboy
Post by coullboy » Mon Jan 04, 2010 10:35 pm
Same thing happened on my 2002 S6 this week, looks like the water gets down the window scraper rubber and freezes in the lock. My one normally opens OK but just bounces open when you try and shut it. I sprayed in lots of WD40 then white lithium grease spray and it seems to have helped.
Next time i'm going to strip the lock and give it a clean and a sevice. It never hapens when you have time! only when you are in a rush!
Saying that it has been -10C up here in Aberdeenshire! not that common.
Regards
Coullboy.
philroach
Post by philroach » Mon Jan 04, 2010 10:44 pm
yes , i am getting the bouncing open jobby as well , once it opens !!! , have tried lashings of WD40 tonight , see what happens tomorrow ???
coullboy
Post by coullboy » Mon Jan 04, 2010 11:02 pm
That's what I like about Audi's! Common faults are a sign of good engineering!
I think my wife made it worse by pouring hot water into the lock, fixed the imediate problem but not so good the next day!
woodlum
Post by woodlum » Mon Jan 04, 2010 11:22 pm
Where about in Aberdeenshire are you coullboy? I'm in Aberdeen city centre (Broomhill) what colours your car?
Users browsing this forum: No registered users and 241 guests
