Occasional beeping when in reverse
2.7 V6 30v biturbo - 380 bhp
Jules
Post by Jules » Thu Dec 17, 2009 3:19 pm
I know this sounds stupid,but a few times recently when i have put my car in reverse to pull it out of the garage,i have heard a beepin sound as if i have reversing sensors.
Is there anything else this could be or have i finally lost the plot :lol:
N11LS_J
RE: Occasional beeping when in reverse
Post by N11LS_J » Thu Dec 17, 2009 3:38 pm
Yep.... you've lost it mate!
you sure it's only when you engage reverse? As mine beeped every couple of minutes when my alarm siren packed up
Instagram : n_i_l_s
Jules
Post by Jules » Thu Dec 17, 2009 3:52 pm
Cheers Nills :lol:
Its probably only done it 3 times in the last 6 months,but it's when ive got in the car and am just reversing out i get about 3 beeps,maybe it is something connected to the alarm then.
Virdee Autos
Trader (Expired)
Post by Virdee Autos » Thu Dec 17, 2009 8:14 pm
Just a coincidence, that when your "reversing" it does this.
But defo the alarm siren.
Park your car the other way round, and see if it does it in the morning, FORWARD!
Virdee Autos ~ 07950-526592
neckarsulm
Post by neckarsulm » Thu Dec 17, 2009 9:59 pm
It'll be the alarm module, VAG COM it and it'll say
01134 - Alarm Horn (H12) 77-00 - Internal Supply Voltage
Sometimes they fix themselves but usually it's the first sign of the batteries leaking and imminent doom.
Tip for RS4 owners, check that your alarm actually sounds!
New unit is round £90 from audi + fitting
dace
Post by dace » Thu Dec 17, 2009 11:08 pm
Jules wrote:Cheers Nills :lol:
Mine does the same, but only when left for a week or so in the garage. It has done this for around 18 months....
neckarsulm
Post by neckarsulm » Thu Dec 17, 2009 11:10 pm
lots of similar reports on
www.tt-forum.co.uk
Virdee Autos
Trader (Expired)
Post by Virdee Autos » Fri Dec 18, 2009 12:09 am
As said around £90, and piss easy to change
Just open the panel in the boot area on the RHS, and its mounted on the floor, with a 10mm nut. And one connector.
The bracket has to be drilled out, as the new siren uses a 13mm nut to hold it.
Some people have split it open (not easy though), and just replaced the battery, which is apparently the same as the batteries used in remote fobs, i.e CR2032/2025, etc
Jules
Post by Jules » Fri Dec 18, 2009 9:31 am
Thanks for all the advice,was expecting a right ribbing :lol:
Like i say its happened about 3 times and the other day when it did it,i had not used it for atleast a couple of weeks.so what Dave said sounds spot on,maybe just when the battery is slightly low on power.
Won't do anything unless it gets worse
Jules
Post by Jules » Fri Dec 18, 2009 9:34 am
Virdee
If i park the car the opposite way round in the garage,i can't open the door,to many car bits in the way :lol: :lol:
Hiltoa
Post by Hiltoa » Fri Dec 18, 2009 11:05 am
Virdee Autos wrote:Some people have split it open (not easy though), and just replaced the battery, which is apparently the same as the batteries used in remote fobs, i.e CR2032/2025, etc
It's pretty straightforward to replace the battery, done it a few times now on various cars. Best do it sooner than later though, as a leaking battery will eventually corrode the circuit board.
Link: http://www.rs246.com/index.php?name=PNp ... ic&t=61888
HTH.
Nothing feels fast for long... :(
2000 Audi A4 TDI 115 SE tiptronic Hibiscus Red 1991 Golf GTi 16v Tornado Red
Jules
Post by Jules » Fri Dec 18, 2009 12:05 pm
Cheers Hiltoa :thumbs:
Users browsing this forum: No registered users and 132 guests
