Fuel Trim: Bank 1&2 (Mult): System too Rich
Diagnostic Trouble Codes (DTC) / VCDS (VAG-COM) forum
KiwiRS4
Post by KiwiRS4 » Tue Jun 30, 2009 1:11 pm
Hi Gents,
Had the engine light pop up on the way home today. Ran VAG-COM across it and found these two codes.
2 Faults Found:
17535 - Fuel Trim: Bank 1 (Mult): System too Rich
P1127 - 35-00 - -
17537 - Fuel Trim: Bank 2 (Mult): System too Rich
P1129 - 35-00 - -
Readiness: 0000 0000
I've cleared the codes but wondering what it could be. Recently (4K miles ago) had the MAFF, N75, 710N and Lamda's changed by Unit20, so I'm not expecting it to be any of those.
Regards,
John
R5CPK
Post by R5CPK » Mon Dec 14, 2009 12:03 am
I know this is an old post but did you find a solution to this?? I have the same fault codes stored. Didn't put the light on though.
2003 8L Audi S3
2007 B7 Audi RS4
1998 B5 Audi S4
2004 B6 Audi S4
2000 8L Audi S3
2001 B5 Audi RS4
S2tuner
Trader (Expired)
Post by S2tuner » Mon Dec 14, 2009 3:46 am
Sounds like a/several boost leak(s) to me.
Post by Shoppinit » Mon Dec 14, 2009 9:11 pm
Makes sense. If air that has been metered is escaping somewhere. What about MAF a problem?
S2tuner
Trader (Expired)
Post by S2tuner » Mon Dec 14, 2009 9:15 pm
Shoppinit wrote:Makes sense. If air that has been metered is escaping somewhere. What about MAF a problem?
Failing MAFs usually throw the opposite codes, "mixture too lean" ;) howzya shoppinit? :lol:
Post by Shoppinit » Mon Dec 14, 2009 9:30 pm
All good, thanks :) Car is running nicely, my head still needs some work though :) Regretting not getting that map when I had the chance ;)
How're you?
S2tuner
Trader (Expired)
Post by S2tuner » Tue Dec 15, 2009 11:31 am
All good, busy as hell as usual, hopefully will see you again sometime soon in Chilly for that map ;)
Return to “DTC / VCDS”
Users browsing this forum: Google Adsense [Bot] and 27 guests
