Post
by HYFR » Sat Dec 05, 2009 9:47 pm
Fully documented Audi history below
I need to call Audi to confirm the dealers of the 10k, 20k & 30k service (i have their certificate which states they were done)
Quite comprehensive...
date mileage audi Types work
26/04/04 13600 audi uk certified SERVICE 10k service
20/09/04 22446 audi uk certified SERVICE 20k service
21/12/05 42106 NOTTINGHAM SERVICE 40k service inc. plugs, air, pollen, oil filters, brake fluid and cambelt, relay and rollers
21/12/05 42106 NOTTINGHAM REPAIR replaced clips for airbag trim, replaced all tyre valves, replaced heated mirror glass for o/s
04/03/06 45722 NOTTINGHAM REPAIR replaced hazard swtich
16/05/06 48642 NOTTINGHAM REPAIR replaced n/s/f engine mounting and replaced pollen filter housing
26/05/06 48846 NOTTINGHAM REPAIR replace convenience unit
04/09/06 53569 NOTTINGHAM SERVICE 50k service
04/09/06 53569 NOTTINGHAM REPAIR replaced handbrake cable holder, replaced engine cover grommets
29/09/06 53573 MOT MOT MOT
08/11/06 57828 NOTTINGHAM REPAIR replaced remote, rebleed hydraulic system
26/02/07 62302 NOTTINGHAM SERVICE 60k service inc. spark plugs, pollen and oil filter
26/02/07 62302 NOTTINGHAM REPAIR replaced rear bumper bracket
02/04/07 63333 NOTTINGHAM REPAIR full DRC replacement
12/09/07 68594 NOTTINGHAM REPAIR replaced vac pipe and replaced oil cooler pipe, replaced handbrake bracket
26/09/07 68600 audi uk WARRANTY warranty renewal
29/09/07 68892 MOT MOT MOT
09/10/07 69329 NOTTINGHAM REPAIR o/s/f outer driveshaft boot split replaced
17/10/07 69655 NOTTINGHAM REPAIR replaced thermostat
11/12/07 71815 NOTTINGHAM SERVICE 70k service inc brake fluid
25/07/08 79995 bexley REPAIR replaced front parking sensors, replaced aircon display unit, replaced aircon pressure switch
08/09/08 81043 audi uk WARRANTY warranty renewal
10/09/08 81484 moT MOT MOT
10/09/08 81484 bexley REPAIR full DRC replacement
10/09/08 81484 bexley REPAIR 2 x accumalator dash inserts, air con ecu, diff seals and 2 x power steering lines replaced
10/09/08 81484 bexley REPAIR new brake discs
10/09/08 81484 bexley SERVICE 80k service inc spark plugs, oil, pollen, fuel filter
01/05/09 8xxxx Aylesbury RePAIR DRC valve replacement, gearbox oil and strainer replacement
01/07/09 88000 Stafford SERVICE 10k service and Cambelt, relay roller change, wheels refurbed
01/07/09 87000 n/a REPAIR X 4 new tyres
01/08/09 90000 Chingford REPAIR replaced n/s/f cv joint
01/08/09 90000 Unit 20 REPAIR new brake discs and health check
22/09/09 91108 Chingford REPAIR replace rocker gasket covers, replace xenon starter, replace 4 shock absorbers
29/09/09 92500 audi uk WARRANTY warranty renewal
22/10/09 93512 Tamworth REPAIR replace alternator
22/10/09 93531 tamworth MOT MOT
