Definitive answer to best gearbox and rear diff oils...
2.7 V6 30v biturbo - 380 bhp
neckarsulm
Post by neckarsulm » Thu Dec 03, 2009 9:58 am
Going to drop my oils today while car is having a thorough going over.
I have searched long and hard for oils info and can't get the same answer from anywhere! I am not near Opie and need the oil today ideally.
So far I know the following;
MRC use OE spec, nothing fancy and I'll go with that.
I am pretty sure 75/90 GL 4/5 is good for the 'box e.g. from GSF;
98048A FUCHS TITAN SYN GEAR OIL 75W-90 4 L L4/GL5 SPEC) 15.50
Where I am confused is what to put in the diff? On the forums people say the diff oil is different to 'box oil and that GL5 should be used but isn't GL4/5 just as good? The only difference I can find between GL4 and GL5 is that GL5 can corrode syncros on older cars at really high temps.
In a nutshell do MRC use the same in diff and box?
And if not what spec do they use?
Thanks!
supersi
oils
Post by supersi » Thu Dec 03, 2009 11:03 am
id just PM Doug or call mrc as there tell you ... top blokes at mrc
Email : simon@turboengineering.de Phone : +44 (0)7825 884236 FaceBook : https://www.facebook.com/TheTurboEngineers
neckarsulm
RE: oils
Post by neckarsulm » Thu Dec 03, 2009 11:17 am
I'd feel bad asking Doug and then doing it myself.
I'll get someone else to ask him (joke) :D
juice
RE: oils
Post by juice » Fri Dec 04, 2009 12:42 am
Hi mate, i used the exact same oil in my gearbox that you searched fromGSF
however in my diff i used silkoline sil tran syn 5 and i think its 75w- 90.
Avus B5 RS4, Miltek down pipes/No cats/Miltek Cat-back, Wagner uprated SMIC's, short shifter, B7 brakes, Phaeton brake ducts, H&R ARB's, H&R Coilovers, AWE DTS, MRC custom Remap + water meth injection = BIG GRIN on my face with poo in my passengers pants
**Now with a Carbon roof**
'Build the best and the rest will follow'
neckarsulm
RE: oils
Post by neckarsulm » Sat Dec 05, 2009 8:52 am
Thanks Juice.
Did you deliberately choose different oils or just do them at different times?
They are both 75/90, look similar spec GL4, GL5 but Silkolene is fully synthetic
Both made by Fuchs!
juice
RE: oils
Post by juice » Sat Dec 05, 2009 5:03 pm
nope, both done at same time, spoke to opie oils who recommended the titan gear oil for the gearbox and the silk tran syn 5 for the diff (fully syn)
speak to guy at opie, he'll probably advise same stuff
Nige_RS4
RE: oils
Post by Nige_RS4 » Tue Feb 02, 2010 2:07 pm
I went for their recommendation and found that 1st to 2nd became much notchier when cold, so I ended up putting the OEM stuff back in.
https://www.speedcams.co.uk
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
Ed 30 Golf DSG - gone
2018 Golf R 7.5
