Custom Exhaust
Custom Exhaust
I have looked at getting at getting a custom built cat back exhaust system built which will be twin 2.5" pipes.
Will it restrict or cause a flow problem if after the back box the tail pipe exits as one pipe and then goes to two pipes? The standard exhaust has the two tail pipes exiting directly from the back box. Thanks
yes it will ..you want twin all the way to the exit
Email : simon@turboengineering.de Phone : +44 (0)7825 884236 FaceBook : https://www.facebook.com/TheTurboEngineers
two in to one will slow the flow as its a sharp bend as such you realy want it as straight as pos . least restriction
maybe if 6" would aviod any restriction but would look <beep> i bet the y pipe in the back box is to keep the noise down i bet
if there both 1 in 2 out then as stumpy says
