Diverter Valve Replacement guide
2.7 V6 30v biturbo - 380 bhp
beejay
Post by beejay » Tue Dec 01, 2009 7:48 am
Just about to replace both DV's and am looking for some advise / DIY step by step guide. Ive searched the forums but not had any joy in finding a post.
Any one got an advise on location and removal steps ?
Thanks in advance
beastman
Re: Diverter Valve Replacement guide
Post by beastman » Tue Dec 01, 2009 8:54 am
beejay wrote:Just about to replace both DV's and am looking for some advise / DIY step by step guide. Ive searched the forums but not had any joy in finding a post.
Thanks in advance
This is link for fitting to S4 assume basically the same
http://www.stratmosphere.com/HyperBoost ... ctions.pdf
Diesel, fuel of the devil!
Blue_Thunder
RE: Re: Diverter Valve Replacement guide
Post by Blue_Thunder » Tue Dec 01, 2009 11:44 am
Might be worth replacing the small vac lines and clips which go to the T-piece between the two DV's when you do this as well.
I've found leaks here in the past.
beejay
Post by beejay » Tue Dec 01, 2009 10:05 pm
Thanks for advice guys - All replaced!
Found very small holes in one of the small pipes - the braided one so will need to replace soonest
Post by Shoppinit » Thu Dec 03, 2009 6:45 pm
What DVs did you put on? 710N? Does anyone know the difference between the 710N and the 710P that I've got on mine?
DutchRS4
Post by DutchRS4 » Mon Dec 07, 2009 12:00 am
Shoppinit wrote:What DVs did you put on? 710N? Does anyone know the difference between the 710N and the 710P that I've got on mine?
710P? Never heard of it.
Stock is 710A, Audi S3 is 710N, don't you mean Forge 007P?
2001 Avus Silver RS4 with 60k miles
100 cpsi full Milltek
710N DV
Awe Tuning Center Vent Boost Gauge
N249 delete
Post by Shoppinit » Mon Dec 07, 2009 10:12 am
The 710P is what goes on the RS6. Same as the 710N but (I presume) with slightly different spring / diaphragm properties. I was just wondering if anyone knew the difference in driving experience between the two.
