Wider rear wheels on an S4 ????
2.7 V6 30v biturbo - 251bhp
2.7 V6 30v biturbo - 261bhp
pegbox7
Post by pegbox7 » Mon Nov 09, 2009 1:37 am
As the title suggests can you fit wider rear wheels on an S4 quattro if the rolling cirumference of the wheel and tyre were matched front to back ?
For example could you have deeper dished rear wheels on a quattro vehicle or will it dammage the drive system ?
Thanks.....
MilkybarKid
Re: Wider rear wheels on an S4 ????
Post by MilkybarKid » Sat Nov 28, 2009 6:49 pm
pegbox7 wrote:As the title suggests can you fit wider rear wheels on an S4 quattro if the rolling cirumference of the wheel and tyre were matched front to back ?
Yes, needs to be pretty damn accurate matching aswell.
pegbox7 wrote:For example could you have deeper dished rear wheels on a quattro vehicle or will it dammage the drive system ?
Thanks.....
I wouldnt like to say it wouldnt and then you went and did it and it did damage your car. Ive never risked it.
pegbox7
Post by pegbox7 » Sat Nov 28, 2009 8:27 pm
what is the reason for this ?
It used to be the same on the skylines that there was always this mtyh that all 4 tyres had to be changed together so that tread depths were the same that it didn't alter the rolling circumference, it even matters which tyres you use if this was the case as they differ in tread depth !
Does this mean you have to match exactly make and tread depth front to rear to make sure the quattro system is not dammaged ?
If not then surely you can alter tyre widths as long as the rolling circumference is the same front and rear ?
I have always wanted to know a difinative answer to this question....
Blue_Thunder
Post by Blue_Thunder » Sun Nov 29, 2009 2:41 pm
Lowrid3r runs wider wheels on the rear of his RS4 I think.
pegbox7
Post by pegbox7 » Sun Nov 29, 2009 5:20 pm
any pics Lowrid3r ? :lol:
would like to see what they look like....
MilkybarKid
Post by MilkybarKid » Mon Nov 30, 2009 10:48 pm
By all accounts you should be able to.
A lot of people when running different tyres (usually different manufacturer) find esp flashes up and have problems that way. Not sure if the differing width would set the same thing off.
Id say go for it, try it out.
Users browsing this forum: Google Adsense [Bot] and 37 guests
