I believe these are tied to flat batteries in the TPMS sensors?
I don't want to spend a fortune on them if it could be something else. As will be fitting new boots next week.
01467 - Front Left Tire Pressure Sensor (G222)
53-10 - Supply Voltage Too Low - Intermittent
01468 - Front Right Tire Pressure Sensor (G223)
53-00 - Supply Voltage Too Low
01469 - Rear Left Tire Pressure Sensor (G224)
01521 - Sensor for Tire Pressure
All help appreciated
TPMS codes - Flat Batteries?
- PetrolDave
RE: TPMS codes - Flat Batteries?
The batteries in the sensors are supposed to last 4-5 years, so if your car is 4 years older or more and still has the original sensors then you most likely need new sensors.
