S4 B6 downpipe mod
giohack
S4 B6 downpipe mod
Post by giohack » Fri Nov 13, 2009 5:52 pm
My muffler shop has proposed me to remove the main cats (maintaining the oem precats). Is it a good idea? :?:
I expect increases in throttle response and a better sound.
Gio
xyber
RE: S4 B6 downpipe mod
Post by xyber » Fri Nov 13, 2009 10:42 pm
Remove the precats, not the main cats. The lambda bosses will need relocating aswell
do a search for 'piggy pipes'
giohack
Post by giohack » Sat Nov 14, 2009 1:08 pm
I read about piggie pipes.. Is it better remove the precats instead of the main cats?
If I remove the main cats I don't need to relocate the lambda sensors.
xyber
Post by xyber » Sat Nov 14, 2009 4:48 pm
If you have just precats it will fail emissions I would think.
BlingBling
Post by BlingBling » Sat Nov 14, 2009 8:16 pm
As xyber stated remove the pre-cats leave the main ones in place. The pre-cats are too close the exhaust and restrictive
xyber
Post by xyber » Sat Nov 14, 2009 8:33 pm
Milltek and the like position their cats in the precat position because the closer they are to the engine the smaller they can be, which saves manufacturing costs, but they have alot more surface area inside them to compensate the size reduction. That position isn't ideal though as placing the cats at the very far end of the downpipes would probably be better power wise from what I've read on ultra geeky exhaust design sites.
I've got full non-res milltek though and highly recommend them. Definatly more eager and alot more punch lower down
giohack
Post by giohack » Sat Nov 14, 2009 9:06 pm
Thanks for your reply.
