Rear exhaust bracket
2.7 V6 30v biturbo - 380 bhp
Imax
Post by Imax » Wed Nov 04, 2009 6:09 pm
Just given my RS4 an early Christmas and also paid the local Audi dealers chrsitmas party... ouch!!! :cry:
When the car went in I knew the rear exhaust bracket was missing and they also mentioned it as part of their standard health check. I ask the cost of replacing and they have advised me I would need to get a complete exhaust, which is close to £500.
:?: I know this is a common problem... is there any other alternative solutions?
The exhaust is secure at the moment so doesn't need doing just yet!!
RS4 2000 - Imola Yellow - 51k miles
GDS968
Post by GDS968 » Wed Nov 04, 2009 6:31 pm
Why replace it if its secure!!
Blue_Thunder
Post by Blue_Thunder » Wed Nov 04, 2009 6:39 pm
Get a replacement bracket welded on for beer tokens at any competent garage.
Imax
Post by Imax » Wed Nov 04, 2009 6:41 pm
Ideally I don't want to replace it and won't until such time as it needs to be done. I was really wondering whether there was a way of fitting a bracket to secure it better and try and prolong the time before I need to do it - Cheers.
ollys
Post by ollys » Wed Nov 04, 2009 7:57 pm
Imax wrote:Ideally I don't want to replace it and won't until such time as it needs to be done. I was really wondering whether there was a way of fitting a bracket to secure it better and try and prolong the time before I need to do it - Cheers.
Mine has been welded twice now - seems ok - are you sure someone competent with a welder could make up a new bracket and fix it?
Your car had a Remus cat back system on it when it first arrived at NJ, but he took it off to put on another car because a buyer liked the sound of it so much. Wonder if that's the reason the bracket is missing. I am sending you that PM now BTW.
Olly
eyeball
Post by eyeball » Wed Nov 04, 2009 9:37 pm
If you have an exhaust specialist near by they will do it for about 15 notes. I use a company called tube torque near macclesfield. It onlt takes 5 mins. Easy job.
Jules
Post by Jules » Thu Nov 05, 2009 11:38 am
eyeball wrote:If you have an exhaust specialist near by they will do it for about 15 notes. I use a company called tube torque near macclesfield. It onlt takes 5 mins. Easy job.
I used to use tube torque about 10 years ago,but started to have a few issue's,i now use jp exhaust's in macc who are excellent with it comes to stainless steel exhaust's
eyeball
Post by eyeball » Thu Nov 05, 2009 12:28 pm
Hi jules, thats exactly what I did. I couldnt remember the name for jp exhausts. infact I dont know if tube torque are still going. Jp are a good set up though.
graemep
Post by graemep » Fri Nov 06, 2009 10:38 am
Got my original one welded for about £15, as it caused an MOT failure.
Someone either here or on SRS was selling an exhaust for about £50 very recently.
Imax
Post by Imax » Fri Nov 06, 2009 8:43 pm
Thanks for your comments... I know alot of you have changed your exhausts and I was wondering if by chance any of you had a rear exhaust bracket that you didn't need?
Audi have said that I need to replace the whole thing and cannot just get the bracket!!!
Cheers :lol:
eyeball
Post by eyeball » Fri Nov 06, 2009 8:49 pm
Take it to an exhaust specialist mate,hey will have brackets already to fit.
Imax
Post by Imax » Fri Nov 06, 2009 8:53 pm
Ah right, as simple as that!!!
no_RS
Post by no_RS » Fri Nov 06, 2009 10:58 pm
Take the mounting off the back of the gearbox so nothing dangling down, never failed at the MOT as exhaust was secure.
