Also i firmly believe in properly warming up and cooling down the engine,its just not worth the risk.
Jinxed
I've had mine over 2 years which also has the mtm stage3 and the only probs have been the same as rsmonkey,small boost leak (split pipe)new maf and n75s,ow and a split cv boot.So not bad at all,i just hope i haven't jinxed it now
Had mine for nearly 3 years and in that time I've had
New clutch (went at 40k)
New flywheel
New DV's
Y pipe leak fixed
New tailgate trim (corroded)
New MAF (last week - original was fitted)
New O2 sensors (last week)
Despite all the above, the car is a beast and is more or less perefect. The tyres cost alot but then the joy to drive it and look after it is such a buzz.
Took it on Castle Combe a few weeks back and really pushed it, if you want to see how well these cars handle then get it on a track!!!
New flywheel
New DV's
Y pipe leak fixed
2001 Avus Silver RS4 B5 60k on clock, MRC Custom Remap, Sunroof, Bluetooth prep
2006 Daytona Grey RS4 B7, RNS-E - SOLD
2006 BMW M6 - GONE
2006 BMW M6 - GONE
jimbo1234567
- 5th Gear
my last 2 years have seen a new, engine ,gearbox,turbos, 2 clutches , steering rack, wheel bearings, suspension bushes, full set of brakes,wiring loom, exhaust, front end respray, then all the usual stuff like 4 n75 valves, maf 2 sets of dv,s , egt,s and lambdas and loads of other stuff and ive only done 25 k going to work and back and 2 trackdays, car is now on 73k,
wanna swap places??
wanna swap places??
665 bhp + 586 lbft...
neckarsulm
Anyone who followed Simon Georges orange Murcielago long term test in Evo will be grateful for the reliability of their RS4!
Considering it only really has a bit more power it took a lot of upkeep for a nearly new car and it too is an Audi really.
Same goes for David Yu's 355 with the same bhp as the RS4.
Unlike these two, I don't read much about RS4s having roadside breakdowns here.
Mine at 103k was well maintained but needed;
DVs
cam chain tensioner (ouch!)
thermostat (so had its 3rd cambelt)
Still on original clutch!
Since then all I get is an intermittent secondary air injection system fault code which can be ripped out anyway.
DVs
In the last 3 years, all its needed is all the diff seals, rear spring, rear wheel bearings, gearbox mounts, engine mounts, instrument cluster, 2 door speakers, cam cover gaskets, cam chain tensioner, new set of hard wheels, window motor, and a £75 power steering pipe that requires the gearbox out!!!! 2 mafs, and all i had to pay for was the 2 egt's and clutch parts!!! thanks to an audi approved repairer who do as they are told!!!! and a great warranty!!!
jimbo1234567 wrote:my last 2 years have seen a new, engine ,gearbox,turbos, 2 clutches , steering rack, wheel bearings, suspension bushes, full set of brakes,wiring loom, exhaust, front end respray, then all the usual stuff like 4 n75 valves, maf 2 sets of dv,s , egt,s and lambdas and loads of other stuff and ive only done 25 k going to work and back and 2 trackdays, car is now on 73k,
wanna swap places??
Is there a specific history to this car? i.e Vandalised & Stolen Recovered x 10?
That is serious Jimbo! You must have some staying power too!
B5 RS4 - Santorin Blue Pearl
B7 Brakes
MRC Custom Re-Map
Loba Camshafts
Wagner Downpipes
Miltek Cat Back SS Exhaust
1988 Pearl White MB Ur quattro (Genesis)
B7 Brakes
MRC Custom Re-Map
Loba Camshafts
Wagner Downpipes
- rsmonkey918
Sounds like Jimbo drives it like he stole it..... Lol
Steve
2000 X RS4 B5 Avus short shift, MTM/full Milltek to 460bhp, 19" Audi split rims/BBS CH's in anthracite, B7 front/rear big brake conversion, H&R ARB's/Bilstein PSS9's/ESP gearbox brace, retrofit RNS-E+Nav, ITG/MRC panel filter
2007 '07 Smart Brabus 101bhp, Bilsteins, Bentley Silverlake
2007 '56 Aprilia RSV Factory for some weekends
2004 '53 Honda Rune NRX1800 for other weekends
jimbo1234567
- 5th Gear
only sometimes. forgot to put 2 broken back springs.
