Anyones help in this matter would be great.....
Non functioning Headlamp washers - HELP PLEASE !!
I have a year 2000 B4 S4 avant with front headlamp washers that don't function at all..i have checked all the fuses etc there has been no front end dammage ever to the vehicle, is there something else that i should check ?
Blue_Thunder
- Top Gear
RE: Non functioning Headlamp washers - HELP PLEASE !!
You can sometimes get air trapped in the lines. Try filling up the washer, then just pump it through loads.
To get the headlight washers to work, you need to have the headlights on and you need to hold the washer stalk for about 2-3 seconds. You should hear the pump change pitch. It must have literally taken me about 20 cycles (no point in holding the washer stalk as the headlight washers only come on for an instant) of doing this before mine finally sprung into life.
Blue_Thunder
- Top Gear
Make sure the washer bottle is full to the top and try again - mine worked in this case but the bottle wouldn't maintain sufficient level. Top it up and see if it stays full overnight. The windscreen and headlights have seperate pumps with the windscreen one being lower down so that it has a reserve. Typically with the headlight pump cracked the water will leak out through it such that you have winscreen washers but no headlight wash.
Users browsing this forum: Majestic-12 [Bot] and 140 guests
