hi guys
had a problem with my gearbox 1st 2nd synchro so having repaired ..thought id change clucth with a new standard kit as it looked a little thin on the skin and plate looked like it had got hot was thinking of replacing flywheel as looked like this had got a little hot but i do think would be fine to use again ..is a light weight flywheel worth going for ? anyone recommend one ?
any info will be gratefully received
regards
si
I'm not an expert on the RS4 but going for a lighter flywheel can affect the idle smoothness and can make it more tricky to pull away smoothly. This is due to there being less energy stored in a lighter flywheel. This in turn makes it easier to stall the car on pull away.
You also need to be careful with regard to the clutch setup as if the flywheel is thinner you may have some issues with the clutch engaging and disengaging correctly.
I would speak to Doug at MRC or one of the other 'specialist' before 'getting all involved'.
Hope that helps?
Hope that helps?
1991 Mercedes Benz 500E
2003 VW Golf GTI 150 PD
- RED_ROCKET
Before my car was stolen, it had a Tanoga flywheel and it was a dream to use with no problems apart from a little bearing noise on lower revs. But improvement in the cars acceleration was very good and highly recommended. I was also using a standard clutch. Money worth spending.
993 Gt2 - Mid life crisis
RS4 B5 -(Disappeared)
Q7 - Family wagon (RIP)
just rang Tanoga and they dont have any for sale and wont be making anymore unless a large order comes his way .
Email : simon@turboengineering.de Phone : +44 (0)7825 884236 FaceBook : https://www.facebook.com/TheTurboEngineers
Users browsing this forum: Majestic-12 [Bot] and 22 guests
