centre armrest
2.7 V6 30v biturbo - 380 bhp
jimbo1234567
Post by jimbo1234567 » Thu Oct 29, 2009 10:26 pm
try grizz he has one.
RS4KID
Post by RS4KID » Fri Oct 30, 2009 6:57 pm
How do i fix this thing on? Do i need to remove the whole centre console? I cant seem to see anything to bolt this on...Can anybody post pictures of the installed unit?
Virdee Autos
Trader (Expired)
Post by Virdee Autos » Fri Oct 30, 2009 8:14 pm
You need to remove the centre console (rear part)
Then cut the hole for the armrest. Should be marked on the underside IIRC.
Then slot the armrest throught the top with the gasket, and then bolt from underneath with the bracket; 10mm bolt, and 3 or so star screws.
Then mount the console back, along with the 3 nuts holding the console/armrest to the tunnel.
Virdee Autos ~ 07950-526592
Imax
Post by Imax » Sat Oct 31, 2009 5:06 pm
Quick question - How do you remove the rear part of the centre console? Reason for asking is that I can remove the handle part if the hand brake but not sure how/if I need to remove the lower part of the hand brake cover to lift the console off.
Thanks in advance...
RS4 2000 - Imola Yellow - 51k miles
Virdee Autos
Trader (Expired)
Post by Virdee Autos » Sat Oct 31, 2009 6:16 pm
There is a tab on the rear part of the handbrake grip.
It basically opens out (towards the centre console)
It's hard to explain, but its just a tab which clips up into the handbrake.
roi354
Post by roi354 » Sun Nov 01, 2009 1:42 am
RS4KID wrote:8DO 864 207 AJ 6DP (6DP denotes Black Colour)
This number was confirmed as a correct number by my supplier. I have ordered the part so will verify this once i get the part...
Thanks for your help[/quote]
Can I ask what the final cost was of this part?
And i you've bought the top half as well what did that cost?
Cheers.
Users browsing this forum: Majestic-12 [Bot] and 22 guests
