Cannot connect to module using VAG Com
Diagnostic Trouble Codes (DTC) / VCDS (VAG-COM) forum
tartan_rob
Post by tartan_rob » Sat Oct 24, 2009 5:28 pm
I have just bought a 2006 A4 DTM for the wife and when doing a few checks cannot connect to either the Engine (I, II or III) or the Airbag module. I have tried it with the latest VAG Com version, v4 and v3.
Other modules appear okay. Any ideas?
Airbag light is on and need to reset it.
2017 Kawasaki Z1000
2014 RS6
2014 S1
tartan_rob
Post by tartan_rob » Sat Oct 24, 2009 6:24 pm
I fixed this...by removing the ABS plug (to the ABS pump) and trying to connect.....all modules accessible.
Weird or what?
I had 1 little gremlin remaining which was the TCS light remaining on the dash. Switched the car off and on and it has gone...
Very weird but all fixed.
2017 Kawasaki Z1000
2014 RS6
2014 S1
PetrolDave
Re: Cannot connect to module using VAG Com
Post by PetrolDave » Sat Oct 24, 2009 6:59 pm
Tartan_Rob wrote:I have tried it with the latest VAG Com version, v4 and v3.
The latest VAG-COM version is 908 - I think you may have an ancient version...
tartan_rob
RE: Re: Cannot connect to module using VAG Com
Post by tartan_rob » Mon Oct 26, 2009 10:10 am
The current version would not work either. I regressed to an older version as I thought that may fix it.
2017 Kawasaki Z1000
2014 RS6
2014 S1
1781cc
Post by 1781cc » Tue Oct 27, 2009 11:08 am
Hi Rob,
Are you using a fleabay cable? just cause I am at the moment (spending too much money on getting a misfire sorted to be able to afford a real one) and have a similar problem.
if you are, where is the ABS plug?
thanks in advance
Lee
tartan_rob
Post by tartan_rob » Tue Oct 27, 2009 12:50 pm
I have a genuine new cable from Ross Tech. The ABS pump location normally is front nearside, above the wheel arch. You'll see all thr brake lines coming out of the hub. There is a large multiplug that you need to remove. If this is your issue....
2017 Kawasaki Z1000
2014 RS6
2014 S1
Dippy
Post by Dippy » Mon Jan 11, 2010 1:39 pm
Rob, any update on this? Currently I can't connect my VAG-COM and I have an EMS warning.
2001 Silver S4 Avant
Return to “DTC / VCDS”
Users browsing this forum: No registered users and 20 guests
