Need to get my two front wheels repaired (Thanks to a quality tyre fitter
Thanks a lot in advance!!!
Stu
http://www.rs246.com/index.php?name=PNp ... 7b7c3aaac1SpeedSix wrote:Hi Guys
Need to get my two front wheels repaired (Thanks to a quality tyre fitter) but as Im away next week I am going to take my wheels off and the leave the car in my garage on stands whiles the wheels go away. What does everyone suggest for the best stand to use and where to put them.
Stu
I lift it kind of simultaneously (using my 2 trolley jacks) first at the front then the rear. I use the lifting points that are designed for scissor lifts, they are further underneath the car than the jacking points which allows good clearance to get axle stands underneath. The picture below should illustrate this I think.GardinerG wrote:Hmmm. Angus, if you use the jacking points to put the axle stands on, where do you put the trolley jacks? Do you lift it a corner at a time or front/back with 1 jack (if you follow what I mean!)?
Users browsing this forum: Google [Bot], srichards and 278 guests
