3 beeps when started from cold
david7m
Post by david7m » Fri Oct 09, 2009 9:51 am
Hello
This has started now the morning temps have dropped, would prob happen in the evening too if I went out ;) Only does it the first time you start from cold, nothing comes up on the dash.
Any ideas?
2001 S3.
APR 270bhp S3, Mixer K6 750
Cheap performance tip - lie the rear seats flat Image
Scotty
RE: 3 beeps when started from cold
Post by Scotty » Fri Oct 09, 2009 11:03 am
Yep - the battery in the alarm needs replacing.....at least that's the common thing when you hear three beeps.
B8 A4 Avant quattro
Honda CBR1100XX Super Blackbird
Suzuki GSXR1000 (Track bike)
B6 S4 (AMD Stage 3) - GONE
8N TT (APR/AMD/MTM) - GONE
david7m
Post by david7m » Fri Oct 09, 2009 12:26 pm
Cheers Scotty
Battery in the key fob? Sounds like the beeps are coming from the boot, ie not the horn. If it is the battery, is it a simple battery out fob, new one in, or is it more involved than that?
Nige_RS4
Post by Nige_RS4 » Fri Oct 09, 2009 1:18 pm
It's the battery for the car alarm which is in the boot (near the sub I think). As far as I can remember, it's not a straightforward job to replace it .... search around. Very common!
https://www.speedcams.co.uk
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
Ed 30 Golf DSG - gone
2018 Golf R 7.5
Nige_RS4
Post by Nige_RS4 » Fri Oct 09, 2009 1:19 pm
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
2018 Golf R 7.5
Post by chunky79 » Fri Oct 09, 2009 3:49 pm
It will be in the nearside rear quart in the boot. If you have Bose it's under the sub. You have to cut open the alarm and change the batt's. You have to do a mod cause you can't get the same batts anymore.
I've just looked for the write up that i followed but i can't find it now.
Don't laeve it too long cause the leaked acid will scrap the pcb.
Dunc
david7m
Post by david7m » Fri Oct 09, 2009 3:59 pm
Cheers Chunky.
The write up would be great if you can find it. What batteries do I need?
Post by chunky79 » Sat Oct 10, 2009 9:09 am
If you cut it open with a junior hacksaw you can take the batts out and go to maplins to match them up. You won't get the exact ones but you'l find some that will work. Will keep looking for the write up.
Dunc
Virdee Autos
Trader (Expired)
Post by Virdee Autos » Sat Oct 10, 2009 7:12 pm
Around £80 for a new one from Audi, if you don't want to cut it up!
Virdee Autos ~ 07950-526592
david7m
Post by david7m » Mon Oct 12, 2009 9:10 am
Virdee Autos wrote:Around £80 for a new one from Audi, if you don't want to cut it up!
Hacksaw it is then ;)
Bluebrakes
Post by Bluebrakes » Mon Oct 12, 2009 12:54 pm
the alarms use a coin battery, which you won't find anymore. So you need to buy two pcb mounted batteries from an electrical supplier such as maplin, solder them together and make the connections to the old battery terminals.
If the PCB is shagged (acid corrosion), forget it!
Why do they call it rush hour when nothing moves!?!
Standard S4, but not for long.
RS4XS
Post by RS4XS » Mon Oct 12, 2009 10:43 pm
wow, i too have this but never realized what it was,
if anyone does find the link please do post
s4marsh
Post by s4marsh » Mon Oct 12, 2009 11:00 pm
most probably a cr3032 lithium watch battery or similar size they cost £3.99.my siren is sat beside on the shelf in my computer room i removed it six months ago when it died, poeple just ignore a car alarm when it goes off anyway and i never leave my s4 anywhere unsafe for very long so can do without untill i have some spare cash,you should test each sensor to see if it sets the alarm off, only one of my interior monitors was working when i checked mine,
Users browsing this forum: No registered users and 98 guests
