Clutch Problems Maybe
Petrolthreads
- 1st Gear
After a week in my RS4, I'm starting to get what I think is a clutch problem, very similar to the one I previously had on my S4.
The pedal has a about 2 inches of travel before it starts to bite, but the main issue is that it seems on occasion to not disengage properly as I come of the pedal. With the S4 if I remember it was some kind of valve or bellows (not a engineer as you can tell) I ended up with 2 new clutches before they worked that out.
Am I being paranoid, anyone else had this issue?
Petrolthreads
- 1st Gear
Yeah, now you come to say it like that I get that sometimes too. Mainly when it's either a) cold or b) after I've given it a bit of welly for a few minutes. There are some threads knocking around about people saying the clutch pipe was originally too narrow to allow the fluid to return back quickly enough or something, and that Audi now fit a larger bore pipe if one comes in with the problem. But I've not had time, or the inclination, to think about it too much yet.
I'd be interested to know where you end up with this. Are you going to take it in?
Petrolthreads
- 1st Gear
Petrolthreads
- 1st Gear
Petrolthreads
- 1st Gear
Chaucer, can you explain more fully please? Is it an Audi mod? So if I just go into Manchester Audi and request the clutch return pipe mod they'll just fit it? I've already queried the clutch with them once but they said 'it feels fine'! I described it not returning properly to them and they never suggested the mod!
Any advice would be great.
Also, can you confirm the actual position re the DRC by any chance? Is there an extended warranty on them?
Petrolthreads
- 1st Gear
Petrolthreads
- 1st Gear
Users browsing this forum: No registered users and 115 guests
