01369 - Alarm triggered by Hood Switch
2.7 V6 30v biturbo - 380 bhp
KiwiRS4
Post by KiwiRS4 » Wed Sep 16, 2009 4:43 pm
Has anyone come across this before:
Control Module Part Number: 8D0 862 257 E
Component and/or Version: CV-Pump, Alarm, RC D17
Software Coding: 15178
Work Shop Code: WSC 63351
1 Fault Found:
35-00 - -
I've recently replaced the battery thinking it could have been that due to running the battery flat.
Any suggestions on where to look first or how to disable to the hood switch within the ECU via VAG-COM.
Virdee Autos
Trader (Expired)
RE: 01369 - Alarm triggered by Hood Switch
Post by Virdee Autos » Wed Sep 16, 2009 6:59 pm
I don't think you can disable it
But might be worthwhile checking its not stuck, as this can happen when your slamming the bonnet. Quite common for the bonnet switches to malfunction.
Virdee Autos ~ 07950-526592
PaulR
Post by PaulR » Fri Sep 18, 2009 10:47 pm
Yes, I've had this. Switch was "chattering" causing intermittent alarm triggering. Easy enough to disconnect the wire form the switch pending a new switch.
Paul.
mylife98
Post by mylife98 » Wed Sep 30, 2009 6:04 pm
Hey,
I had this hood switch problem early on in my RS4 days. Switch turned out to be cracked.
It's not to bad to replace yourself. It's one of the first write-up I did, so the embeded photos links aren't great, but all the photos are still there. Have a look: http://www.rs246.com/index.php?name=PNp ... highlight=
M
Audi B5 RS4 Standard. Avus Silver. Debadged. Supaglass.
Users browsing this forum: No registered users and 99 guests
