Milltek "Bulk Buy"
what are the advantages of a miltek, apart from the sound obviously , guaranteed power and torque increases ?, if so , by how much?
are these prices fitted , near surrey ?
Stuart6587
Price includes fitting.
Suggest you look on the Milltek website www.millteksport.com and it will give you all the info your require either under Products or FAQ.
Number of benefits including Stainless steel (lighter and longer lasting), More power/torque, Releases the V8 sound muted by the OEM system, etc.
Mine is standard, 6 1/2 years old and 100K miles, and apart from a slight leak at a joint (simply repaired) seems to be going strong.
Main benefit of an upgrade is if you do it with a remap - let's the whole system breathe better so you can extract 5% more from it. If you follow this route the map needs to be done with the new exhaust on so as to get the best from the system.
I'd be surprised to see that much without tweaking the ECU to take advantage of the exhaust. The system does do some self adjustment (as it does with fuel etc) but not sure it is that capable!
Most of the tuners reckon they get to around 500 with a Stage 1 remap, and then with new exhaust, airfilters, etc get to about 540-550 for Stage 2. ie, they get 8-10% but it also requires freeing up the incoming air, and adjusting the map.
Personally the exhaust is on my list for when the standard one fails, but not before - I can't justify the full cost, but the differential makes it well worth it!
Same here. 'Though I've got the Audi sports exhaust which I guess falls somewhere between the standard one and a Milltek. I find it ok noise wise; sounds mean when it's hot. But, would most likely change it if I ever got a remap done. That too is a low priority at the mo.jd_hants wrote:Yes I am of the same thinking. Keep the standard one until it fails. There are other things (like a cambelt change) which take priority at the moment.
Stuart6587
Further update as Grizz (Unit 20) has come up with a great deal as follows:
0-5 units = 15% discount
6-10 units =20% discount
11+ units = 25% discount
Surely with these discounts we can get 11+ to benefit from a 25% discount.
So far the following have expressed an interest:
1) Stuart6587
2) Rob8457
3) Spanner1210
4) Nudenut
5) JDS67
6) Alexrs6+
so further replies awaited.
1) Stuart6587
2) Rob8457
3) Spanner1210
4) Nudenut
5) JDS67
6) Alexrs6+
discounts from what base figure , and prices fitted / not fitted ? grizz good as he is , and he is , is a 500 mile round trip , which is a lot of pound notes to add to the equation
slimmyreed
I was planning on just having my silencers removed with a straight bit of pipe welded in
May not see the same sort of power increase (is being remapped too) but should get me the noise I'm pining for!
But if i can get a suitably cheap miltek i may be persuaded (I am in oxford though, so driving to unit 20 isn't really practical for me...)
But driving to Banbury (MRC) is about 20 mins - and they do Miltek too!! So go get yourself the full stage 2 treatment and a grin from ear to ear!!I am in oxford though, so driving to unit 20 isn't really practical for me...)
In fact - looking at your gearbox posting I see you are going there next week - all done in one trip sounds good to me!!
Users browsing this forum: No registered users and 555 guests
