Hi there.
I was wondering if someone might have a Fuel Pressure Regulator for my S4 1999... Its coming up in Vag Com that this might be at fault (running lean on both banks) I have ran a pressure test through and didnt find any air leaks so this is my next option.. Does anyone have one for sale or knows what to replace it with...
I have checked on fleabay and they have adjustable ones... Does anyone know what these are like... any suggestions at all would be great thanks... I remember the stealers wanting around the £70 mark for them... if anyone can steer me in the right direction... any advice would be much appreciated...
Andy
Wanted - Fuel Pressure Regulator
- boxerdogted
RE: Wanted - Fuel Pressure Regulator
How old is your MAF ? and when was your fuel filter changed.
2001 RS4 Misano Red
Both of these were replaced just a few months ago... The maf was changed out when i got the car remapped and the fuel filter was changed out on the last service...
Andy
Andy
- boxerdogted
Take FPR off and check for dirt etc there is a filter in there.
Gareth
Gareth
2001 RS4 Misano Red
I didnt know that Boxerdogted... I will try taking it off and cleaning it. What do i use to clean/rinse it with?
Andy
Andy
- boxerdogted
Blow out any crap with an airline and check that it is not stuck open causing low pressure.
Remove the horseshoe clip and pull out, they are very tight to get out as they are sealed with two o rings.
Gareth
Gareth
2001 RS4 Misano Red
Cheers Gareth... Will try this and let you know how it goes... Cheers for the advice... much appreciated...
Andy
Andy
Well i have just removed the FPR for cleaning the filter and there was nothing there. It was totally clean. It was a bit of a bugger to get back on but at least it was clean. I was hoping it was blocked but no, so what else can i try.
Would a upgraded FPR say from a rs4 be better or are these the same. On the FPR it says 4 bar... P/N - 078133534C
Any suggestions would be appreciative...
Andy
Andy
