Tyre pressure sensors - again
Post by HYFR » Fri Sep 11, 2009 1:05 pm
im gonna ask them to sort mine under warranrty - seeing as though they're fixing everything else on the dam thing
Post by Shoppinit » Fri Sep 11, 2009 1:14 pm
Just come across these TPMS at Kufatec. Might be of interest to some:
http://www.kufatec.de/shop/product_info ... -Audi.html
Post by Shoppinit » Fri Sep 11, 2009 1:19 pm
Just noticed that it says for 4F. DOn't know if they'll work with ours.
jd_hants
Post by jd_hants » Sat Sep 12, 2009 4:25 pm
hey thats an even better price than the £75 each I paid and I thought that was good. Like you say, depends if they work on not. The ones I got definately work.
Post by Shoppinit » Sat Sep 12, 2009 5:27 pm
The part number for the RS6 C5 is 4F0-907-275 C and 4F0-907-275 B for the C6 RS6. They look the same, but I suspect the frequencies might be different.
Apparently Beru make the sensors (or compatible ones)
jd_hants
Post by jd_hants » Sat Sep 12, 2009 5:51 pm
yes ones i got were beru. thats same part number www.alloywheelsdirect.net quote but they dont specify the letter. the ones i got were orange. they say the previous ones were grey. thats probably all the letter means!!!
MalcolmSu
Post by MalcolmSu » Thu Sep 17, 2009 8:48 pm
had one of mine changed over yesterday by Audi Stirling. Sensor was A4B3 907 275 C and was £103.05 plus valve A4D0 601 361 and £10.79. Labour was £32.50. And then plus VAT. £171.95
philroach
Post by philroach » Thu Sep 17, 2009 10:11 pm
MalcolmSu wrote:
Shoppinit wrote:It's inside the rim. It hangs off the valve stem inside.
No special attention. Just make sure they don't break it. You can change the valve cores, no problem. They are standard.
Interesting picture - i see the RFID transmitter is 433MHz which is the same frequency as most the devices in my home automation system. This means if the signal is strong enough when the car is my drive I should be able to examine what the receiver is receiving, log the pressures and detect any variance! The car should be close enough as there's already a sensor under my front seat that's read by the house when the car comes home (or leaves) - check out the front drive at http://217.155.28.94:8080/stat (guest & guest). :-)
kin 'ell , are u related to bill gates or someone similar !!!! what is the sonos system like , have been sniffing around that myself
MalcolmSu
Re: .
Post by MalcolmSu » Thu Sep 17, 2009 10:58 pm
[quote="philroach]what is the sonos system like , have been sniffing around that myself[/quote]
of all the gadgets I've bought over the years - and you can see there are many! - Sonos is the one that gets used the most on a daily basis and by all the family... It's so easy to use - even my wife uses it. Coupled with a Napster subscription I can play any of 8 million tunes anytime. :-)
It is expensive but I think it's worth it. Don't buy their remote / controller though - I use an iPod Touch.
GregR1
Post by GregR1 » Sat Sep 19, 2009 9:11 am
Picked up the car last night after the front two sensors were replaced FOC. Got 4 miles down the road .. then the dreaded TPMS warning came back on. These things are a right pain in the chuff!!
On the bright side, I did get my free wipers and my free alloy refurb too ;)
jd_hants
Post by jd_hants » Sat Sep 19, 2009 11:08 am
Presumably you re-stored the typre pressures??? does it tell you which ones?
GregR1
Post by GregR1 » Sun Sep 20, 2009 11:34 am
Never thought about re-storing the pressures. All I get is the orange picture of a tyre with a '!' and a line through it. Will try to re-store the pressures and see what happens.
MalcolmSu
Post by MalcolmSu » Sun Sep 20, 2009 1:54 pm
GregR1 wrote:Never thought about re-storing the pressures.
would have thought the dealer would have done that when they replaced the sensors?!
GregR1 wrote: All I get is the orange picture of a tyre with a '!' and a line through it.
That's what I had - dealer stuck it on their computer and said one of the monitors had failed.
Post by Shoppinit » Sun Sep 20, 2009 4:21 pm
GregR1 wrote:All I get is the orange picture of a tyre with a '!' and a line through it.
I get that when I turn the sensors off.
jd_hants
Post by jd_hants » Sun Sep 20, 2009 4:46 pm
Yes I had that symbol when I first got the car - wondered what it was - its either when the system is switched off OR, like me, I didnt have any sensors fitted!!!!
So, once I fitted the new sensors, I switched the system off, then on again, then stored the pressures. And (fingers crossed, touch wood and all that) its still working. These were the orange BERU sensors I got from Alloywheelsdirect.net!
Users browsing this forum: Google Adsense [Bot] and 115 guests
