You should get an error like this:jd_hants wrote:Ah so there must be a way to check each one.
Anyway, I'll get my wheels back tomorrow so I'll pist whether the £75 ones work or not!!!! The website quoted an OEM part number but I havent seen one apart from the ones I bought so cant comment on whether it was the same or not.
01467 - Front Left Tire Pressure Sensor (G222)
53-00 - Supply Voltage Too Low
If not, then you'll have to use the measuring blocks to try and identify individual sensors. This from ross-tech wiki:
raise or lower the pressure in one tire at a time and double check the Measuring Value Blocks (MVB) 001-012 (and 016) for changes. If you find one which does not change after raising or lowering the Pressure, you have most likely found the faulty Sensor.
Note: It may take up to 2 minutes before a pressure change is detected by the control module and displayed in the Measuring Value Block (MVB). To locate the individual Wheels it helps to make a note the Sensor Identification Number.
