http://www.youtube.com/watch?v=0hoYhfecx-k
thoughts on if this is the dreaded bad cam ticking. hope this helps others cheers
rs4 possible bad cam vid on youtube....
neckarsulm
RE: rs4 possible bad cam vid on youtube....
Sounds like cam chain tensioner to me but then I wouldn't say that method of recording sounds was ideal.
yeah best i could do at the time
my injectors sound like they could use cleaning
Sounds Exactly like mine did and after checking every cam lobe lobe was perfect, i did check the cam chains and they were fine too, remember theres 30 valves moving, 30 valve springs moving, 4 cam shafts turning, 30 hydraulic tappets, how quiet can they make them? it is a supercar!!!! you heard a porsche 996 turbo idling?? sounds like someone dumped some nuts in the oil filler!
