Brake problems
crazymazy225
Brake problems
Post by crazymazy225 » Wed Aug 12, 2009 7:51 pm
I have had the car for a week now and i think have made a serious mistake by letting the local tyre shop centre, replace front genuine audi discs and ferrodo pads. When i get to 80 ish the vibration through the steering wheel is really bad. I have taken it back 3 times and have had the wheels balanced times 3 and the brakes stripped and checked. Took it out today and the same problem although when the vibration started i touched the brakes and it disappeared - weird ! I have now booked it into a AUDI specialist not Audi themselves tommorow. Any input appreciated as i am really concerned !
TIMSRS
RE: Brake problems
Post by TIMSRS » Wed Aug 12, 2009 7:53 pm
Check the mating face where the disc sits.
Any dirt or rust on that facing will throw the disc out of balance.
crazymazy225
Post by crazymazy225 » Wed Aug 12, 2009 8:01 pm
Will mention that tommorow, cheers - Also before the brakes were done the car had driven perfect.
matt1979
Post by matt1979 » Wed Aug 12, 2009 9:04 pm
i have the same problem and have given up trying to solve the problem when im doing real high speed it shuders the front of the car iv had 3 garages try to sort it and still aint sorted it it was fine b 4 i had the h & r put on it and after trying 3 diffrent lots of brakes im thinking of changing the suspension
scania 144 v8 chipped from 460 bh to 580 bh. a6 2.5 v6 silver and changed to rs6 v8 500bh avus silver and loving it!!!
crazymazy225
Post by crazymazy225 » Wed Aug 12, 2009 10:57 pm
I will see what the garage say tommorow. Was your problem after brake fitting or h+r first ? I thought the h+r actually replaced the suspension ?
nekrum
Post by nekrum » Wed Aug 12, 2009 11:17 pm
matt1979 wrote:i have the same problem and have given up trying to solve the problem when im doing real high speed it shuders the front of the car iv had 3 garages try to sort it and still aint sorted it it was fine b 4 i had the h & r put on it and after trying 3 diffrent lots of brakes im thinking of changing the suspension
Got H&Rs on mine without any brake issues?!.. Sounds like a brake issue i would have thought, maybe something inadvertently damaged / miss fitted when the H&Rs were done?!..
Also are you getting a shudder at speed or while braking at speed?..
jd_hants
Post by jd_hants » Thu Aug 13, 2009 10:37 am
No idea whether this is true or not but I was chatting to someone a couple of days ago about skimming discs and they thought that discs themselves are also balanced??? Also, he had been told that wheels can be balanced ON the car to illiminate unbalanced driveshaft/hub/disc etc.
Anyone shed anylight on this I've never heard of it before but it does actually make perfect sense.
crazymazy225
Update
Post by crazymazy225 » Thu Aug 13, 2009 3:13 pm
The Audi specialist examined the car this morning and reported the discs are warped. I have taken the report to the original garage that fiited the discs, they very good and have taken the car to investigate themselves. There conclusion is, if the discs are warped then the car will go back to an Audi main dealer for a warranty claim on the discs, which is fair enough. I gave them the option to supply the discs only which i would have got the Audi specalist to fit which would no longer be there problem. But they want to sort the problem out themselves. Will keep you informed.
nekrum - Shuddering badly when braking from 80.
jd_hants - Audi specalist could skim the discs but no warranty at all against future warping. I paid for new discs so this is not an option.
dace
RE: Update
Post by dace » Thu Aug 13, 2009 3:28 pm
Common problem on these discs. I have had two brand new sets and each time one disc was warped?!
nekrum
Re: Update
Post by nekrum » Thu Aug 13, 2009 4:19 pm
crazymazy225 wrote:The Audi specialist examined the car this morning and reported the discs are warped. I have taken the report to the original garage that fiited the discs, they very good and have taken the car to investigate themselves. There conclusion is, if the discs are warped then the car will go back to an Audi main dealer for a warranty claim on the discs, which is fair enough. I gave them the option to supply the discs only which i would have got the Audi specalist to fit which would no longer be there problem. But they want to sort the problem out themselves. Will keep you informed.
Makes sense - good to know for future reference.. :D
crazymazy225
Post by crazymazy225 » Thu Aug 13, 2009 6:50 pm
The garage has now agreed the discs are warped and have ordered new discs for tommorow. I have told them to use Audi pads this time at my cost just in case ! Next time i think i will bite the bullet and let main dealer suppy + fit. Just want my Hearse back !
Cornishmoocher
Post by Cornishmoocher » Thu Aug 13, 2009 9:26 pm
there is more to this than meets the eye.
i have had no problems and know of many more peeps that have the H&R's with no issues, its impossible to feck up. To warp a set of disks, especially the C6 disks you have to be a loon.
i recently TRIED to warp a set, TRIED to get brake judder, and all to no avail.
I would be checking bushes and bearings, drop links and arms.....
It's all Bollox.
Cornishmoocher
Post by Cornishmoocher » Thu Aug 13, 2009 9:32 pm
So, are you back on standards then and its STILL doing it????
It's all Bollox.
matt1979
Post by matt1979 » Thu Aug 13, 2009 11:33 pm
hi guys answers to the above 1 at a time..
crazy
h & r were fitted at the same time as new brakes and iv had 3 sets of brakes since and still have a bad shudder when brakeing from high speed.
nekrum
it only happens when braking from high speed.
id hants
yes disk are balanced and wheels can be balanced on the car which im thinking of having done but i have had wheels balanced more than onece and it makes no diffrence.
cornish
yes the car has had all uprated brakes taken off all the way round the car and all back on standards the shuder is better than ever but you can still notice it a little bit when brakeing from high speed it is livable now but not right i cant get my head round it but it use to do it at 80 mph but now only does it at much higher speeds. something aint right as it never done it befor h & r and new brakes were fitted i am still going to take it back to the last garage truck align they are top top people at aligning all sorts of cars and trucks but dident want to waste anymore time on it untill i had the car put back on its full ariginal brakes..........
Mac-Logotech
Post by Mac-Logotech » Fri Aug 14, 2009 1:48 pm
My old discs were skimmed and put back on. Worked perfectly
54 AUDI RS6 AVANT
2001 BMW E39 M5
1997 Volvo V70R AWD
Users browsing this forum: Google [Bot] and 256 guests
