Bluetooth - handset(s) will not connect car
Hi, have owned my RS4 for over 2wks now and have not managed to connect my phone handset to Bluetooth.
I have a Nokia 6301. Have tried Samsung D600 and also my wife's Nokia (can't remember her model no.).
I can always "find" the car but when I go to connect it fails..
Audi say the car will only work with certain handsets and then start going on about software in the phone.. I'm not sure whether to believe this, I thought Bluetooth was, well "Bluetooth"!
My old 350Z had no problems with connecting with my phone, and my wife's Peugeot 207, the same.
Any ideas, appreciate some advice?
Nick
Nick
PG, yes it does. The handbook suggests the pin is 1234. I get that far and for a split second it says "connecting" but then says "failed".
The phone is enabled already as I used to connect to my old car automatically without issues. Or am I missing something. I would have thought 3 different types of handset failing to connect would point towards a problem with the car.
It's going in for some minor warranty work in a couple of weeks and I've added the bluetooth problem to the list. If Audi can demonstrate that a handset I've not tried yet works on the car then I'll be happy to look into changing mine..
If anyone knows the list of suitable phones could they post it? Im about to change my nokia n95 for something that i like AND will work properly in the RS,a real bonus would be being able to get a cradle aswell,ive got used to the nokia and fancied the n97 but orange tell me all the n series are renown for dropping there bluetooth connection!
Are they? early ones were, but all the latest N series are fine.
Only problem is the age of your BT module in the car, only the latest ones fully sync with the N series.
Q modules work ok, but require the contacts downlod manager to be installed
S, N & AA modules all work fine with the XM5800 and N96, N97
- PetrolDave
IIRC the 8GB version of the N95 doesn't need the Nokia Contacts Manager installed (which you get from the Nokia website), but it might be worth installing it anyway since it won't cause any harm.lengster1 wrote:My current phone is the 8gb n95
But as craigyb has already said the N95 does need a pretty recent version of the Bluetooth module - maybe your problem is that the Bluetooth module in your car is too old to support the N95?
The reply from Orange is just bullsh*t, the non-technical idiot you spoke to is referring to the WCDMA/3G frequency of 2.1GHz - which has nothing at all do to with Bluetooth problems.
Were is the module located in the car? I think i best check what the part number is,the phone hooked up once but has never auto connected since and was useless when i tried using it,i was in good area for reception but really poor connection quality,sorting this is high on my TO DO list any help would be appreciated
- PetrolDave
Oh well, mine must have been retrofitted as that is where it is, but then the car has always had the module from the factory (supposedly) so not sure why?PetrolDave wrote:ONLY if it's a retrofitted module...P_G wrote:It is under the dash on the passenger side
Factory fitted Bluetooth modules are in a plastic box under the carpet under the drivers seat.
The easiest way to see the version letter on a factory fitted module is with VAG-COM.
Users browsing this forum: Bing [Bot] and 225 guests
