Rear Brake Pad/Disc Combo Advice Required
2.2 I5 20v turbo - 315 bhp
darkhorse1210
Post by darkhorse1210 » Mon Aug 03, 2009 10:58 am
Gents
Just wondering if anyone can provide advice on which rear discs & pads to put on the RS2?
I've read some historical posts on this topic and it appears that the Ferodo DS2500 pads are the top pick.
Advice on discs is varied, tried getting my head round the 'big red' upgrade but gave up on that. I have EBC discs on the front (not sure if that is the brand or distributor?) and the only problem there has been the well documented squeel when you come to a standstill. They are not drilled or vented.
Not an urgent change as they seem to have about 5k in them but I need to replace the disc carrier which means stripping the wheel down so was contemplating getting all done at once.
Also I need a new rear wiper motor but have been quoted £145 for the part alone, anyone know where I can get one of these a bit cheaper? Seems expensive to me.
darkhorse1210
Post by darkhorse1210 » Mon Aug 03, 2009 4:27 pm
Since this morning's post I have been offered the following:
Mintex or Pagid pads at £50
Bremtech vented rear discs at £210 for the pair
Seems pretty reasonable to me....any thoughts??
Tom
alastairg
Post by alastairg » Tue Aug 04, 2009 9:16 am
Just need to make sure the rear discs are correct. After several have had false starts with porsche rear discs that were meant to fit. Most go OEM at about £210 each.
RS2 'an estate car named Desire'
DickyC
Post by DickyC » Tue Aug 04, 2009 1:57 pm
Independant Porsche specialist Ray Northway in Reading, who I've known for years, was unable to ID my old discs with any confidence. "They look like..." was as close as he could go. And he ran an RS2 for a while!
I'm with alastair, get the proper ones and be amazed how much better they are than what you have now. Even the handbrake will suprise you.
Volcano Black 1995 RS2. Standard.
Gone - but understood to be alive and well and living in Cornwall.
Return to “RS2 (B4) 1994-1995”
