B7 Brake upgrade.
2.7 V6 30v biturbo - 251bhp
2.7 V6 30v biturbo - 261bhp
PretendPorsche
B7 Brake upgrade.
Post by PretendPorsche » Tue Jul 21, 2009 8:03 pm
I know there are already threads on here regarding fitting the b7 setup to the b5, which seems super easy, only thing is do i need to change the hoses, or is that just good practice when ive got the calipers off?
Thanks.
Virdee Autos
Trader (Expired)
RE: B7 Brake upgrade.
Post by Virdee Autos » Tue Jul 21, 2009 10:54 pm
Best to use the RS4 hoses, as the hose fitting on the original hoses is not suitable for the B7 calipers.
Virdee Autos ~ 07950-526592
PretendPorsche
Post by PretendPorsche » Wed Jul 22, 2009 12:17 pm
Also just thinking another problem could arise here, are my 19" bbs ch's actually going to fit over the b7 setup? i am using a spacer?
If not anyone want to swap 19" for 18"????!!!!!
philipwalker
Post by philipwalker » Thu Jul 23, 2009 3:57 pm
What is the wheel number of your CH`s?
CH026? CH009?
http://www.pwmotorsport.com
PW Motorsport
01437 563929
PretendPorsche
Post by PretendPorsche » Thu Jul 23, 2009 4:29 pm
Good question, seems to be some confusion between myself the bbs application guide and the garage i got them through, need to check the actual wheel when im with the car next! What am i hoping for?
philipwalker
Post by philipwalker » Thu Jul 23, 2009 5:12 pm
The 19" CH026 are ET50mm that are often spacered to suit the S4.
The 19" CH009 are the correct ET35mm.
The 18" wheel CH012 will fit straight over the B7 RS4 setup.
The number will be cast into the rim.
If you have any questions give me a ring.
PW
01437 563929
PW Motorsport
01437 563929
PretendPorsche
Post by PretendPorsche » Mon Jul 27, 2009 11:47 am
Well that didnt go as easily as hoped!!
Fitted the b7 setup over the weekend, finally got it all on there, but as expected the wheels are causing me problems!!
I am now running a 25mm spacer on the front (could get away with 20mm but 25mm was all i had) so the wheels clear the brakes but now rub on the arches!! Probably wont once the 20mm spacer is on the front, but then i am running 215 tyres, which i need to change to 225!! So im guessing they will rub again then!!
Do you think the 18" ch012 will solve all my problems??!!
