Hi
I recently took my RS in for some warranty work on the suspension and I was told that my pads are 70% worn and my discs are scored. They stated that the pads would be OK until the next service (4-5k miles away). When I mentioned about the problems with pins on the pads scoring the discs they stated that the scoring was caused by a stone or similar.
Having read the post regarding pins causing disc scoring prior to the warning light coming on, have Audi got a case to answer because I am sure that the scoring on the disc is consistent on both which would indicate to me possible damage caused by these wear indicator pins.
I have no brake squealing or judder indicating worn discs. The car is a Jan 07 24k.
Views or advice please before I contact Audit Customer Services
PS The dealership have stated that I don't require new discs
My understanding is that the latest OEM pads have been upgraded to resolve this problem - is this now the case? The part number ending in Q.
Also any advice on remaining with OEM pads with a view to any future warranty claims.
Thanks for your help.
Brake disc scoring and pad wear
RE: Brake disc scoring and pad wear
Utter b%llo*cks i changed my front discs and pads due to this,discs would of done another set of pads if it hadnt been for the scoring from the pads.No warning lights on nothing just the pads/pins merrily destroying £500 discs, my car has 27k on the clock,im debating having the old ones skimmed but it will put them close to the 32mm limit,they have modded oe pads now but dont want to know about customers cars that have had expensive discs eaten by origonal set
my old pads were scoring the discs even though the stealer said they had 50% wear left, i got they them to replace them FoC with the arguement being if i waited till the warning lights came on the discs would be ruined....
If you have three concentric rings on your discs, which line up with the location of the pins, I'd suggest to Audi that they might like to consider their position again as the chances of 3 stones getting stuck in the exact same location as the pins must be statistically remote.
About as remote as finding a good Audi dealer.
Stick with Camberley Audi.
As for changing pads from OEM, not only might you invalidate your warranty but your insurance too...somethings just aren't worth pi**ing about with until you're out of warranty...
IMHO.
IMHO.
58 C6 RS6 Stage 2+
58 C6 A6 Allroad 2.7 TDi
Previous:
2000 B5 S4 MRC 550 Saloon
2007 B7 RS4 Saloon
1994 S2 Coupe
Previous:
2007 B7 RS4 Saloon
1994 S2 Coupe
Check the following thread
http://www.rs246.com/index.php?name=PNp ... c&start=15
Sorry still haven't got any measurements.
Good picture here
http://zeckhausen.com/Audi/RS4.htm
A bunch of folks in the US including me have those Centric Posi pads to replace the stock ones. Way way less dust, no noise, braking is fine.
Users browsing this forum: EireRS6 and 163 guests
