Power loss at wheels
Does anyone know much about what is meant by power loss at the wheels on a RR?
I ask because Sita has the same car as me, same wheels, same brakes, same spacers and his car shows a 38% loss but mine showed a 51.1% loss?
Dunc [img]images/graemlins/s3addict.gif[/img]
Re: Power loss at wheels
Could be semi-fault MAF pulling back the power or Flywheel problems? Just a guess.
Riz [img]images/graemlins/s3addict.gif[/img]
I`m just a hardcore petrol head Re: Power loss at wheels
Not sure about that as the power loss figure at the wheel were different for a few other cars too. CliveDs TTR showed 53% loss (but with good figures) and Simon Elman had 60% loss (his car appeared to be down on power too - 269bhp 323lb/ft)
I had 150 bhp at the wheels
Dunc
Dunc
Dunc, for what it is worth, I intend to discuss a few things with AmD next week so I'll get them to explain the measurements in more detail and I'll post this on here for us to all mull through.
Personally i have to say that things need some explanation and clarification regarding these results.
[img]images/graemlins/thumbs.gif[/img]
~27 / 28%
How did you get 50% ? Are you calculating RR power down againt factory spec ? If you, you probbaly have a boost leak.
2014 RS6 (2023 on order)
2017 Q7
1993 E36 M3 Tarmac Rally car
2001 Porsche Boxster circuit car
2017 Porsche 991.2 GT3 Clubsport
2017 Q7
I had 180BHP at the wheels with a 40% loss through transmition etc.
I'll get the graphs etc scanned this morning and post them up.
- ChelseaMick
Here's my summary...
[img]images/graemlins/beerchug.gif[/img]
Mick
MTM 265.3bhp & 307.3lb Torque
Mick
- ChelseaMick
Nice curves!
Mick
Mick
- ChelseaMick
Mick
Mick
~27 / 28%
Thats the thing I dont understand why/how/what this percentage means. Apparently my car wheels are a bit bent and the car was causing a lot of vibration on the RR. I have done some logging on my MAF, Timing and also requested vs actual boost, and there does not appear to be any obvious problem with the car.
Plots.
hmm bit of a booost spike there Ben... I wonder if that is due to adaptation. Without that spike, it looks like your torque would have been about 270 ish consistently before tailing off.
Apparently it could be when the wastegate closed. But to be honest I don't have a clue [img]images/graemlins/grin.gif[/img]
i thought ECU adpation only worked when the engine ECU settings had been altered...... so in theory if you`ve not changed any settings prior to the RR day then no adaption should happen.I wonder if that is due to adaptation.
Could your spike be a hose on its way out?
MAF could be faulty and wont always show problems..... one of those once in a blue moon problems or under non-common useage, i.e. a RR.
On the road the MAF may be running under optium specifications and ranges.
Sticking DV?
The only other thing it might be is loss of grip on the roller.... tyres?
-I changed settings on the SPS a moment before it went on.
Could your spike be a hose on its way out? -
- They would have said if a hose was bad, you'd hear it anyway.
- Had a new MAF recently.
Sticking DV?
- DV is a good 'un mate.
- Take more than 260BHP to get wheelspin on those [img]images/graemlins/grin.gif[/img]
[color="red"] Good ideas all the same [img]images/graemlins/colflash.gif[/img] [color="red"]
Ben
