RE: Only 255whp - I have a problem.
Ouch, that must be painfully slow to drive
Dave
Dave
APR 270bhp S3, Mixer K6 750
Cheap performance tip - lie the rear seats flat
new engine so cant be coking......................?
maybe stuck exhaust flaps? air intake flaps?
fingers crossed for you buddy
07/57-B7 RS4 Saloon-Sprint Blue,Tech Pack, DRL's,Bluetooth,Carbon Trim,Chrome Optics,Sunroof,open zorst flaps,FBSW,Bose,Buckets,New Boots,R8 alu oil cap,BMC panel,RS plate,Fresh plugs,10mm Rear H+R spacers courtesy of Virdee.
Also - 1970 MGBGT for Hillclimbing and Sprint racing
03/53 - MK4 Deep Blue Pearl R32 3 door (sold)
"You never hear a truer word spoken in jest"
Variences between dynos aside I think the norm. whp is around 300-310 so it does look low.
These engines are known for lossening up as the miles go on, 1k I very refresh. Also, what is the heat in Dubai ?!
did not know you was in dubai, not surprised you are only getting that kind of power its got to be at least 40c+ im in bulgaria and the temp here is in the top thirties sometimes 43-44c and im way down on power, so i would say the heat is to blame ive been to dubai many times at this time of year so i know what it must be like at the moment, i even took my rs4 in to the mountains a few weeks back where it is much colder and the car was back to its normal self as soon as i came back down i lost loads of performance..
is there a break in code on these cars?
limiting performance for say 1200 miles or first service?
looks like it's restricted > 5500 RPM
fell flat on its face and would not rev to redline apparently...
vaccum leaks, bad software, something is wrong
Re: RE: Only 255whp - I have a problem.
Last edited by matthew.lewis2 on Tue Jul 16, 2013 3:52 pm, edited 1 time in total.
- PetrolDave
- Top Gear
Seems odd that the AFR is holding pretty much perfectly at 12.7 above 5000 rpms. If it was just a duff MAF would you not expect to see that figure going up and down as the ECU constantly corrected for the lambda readings? (unless the ECU is programmed to ignore the lamdba readings above a certain rev range)
Re: Only 255whp - I have a problem.
matthew.lewis2 wrote:Well, after 1000miles on my new engine I went to have the decats and remap installed.
According to the run in procedure, you should not use full throttle for 2500km and not more than 6000rpm up to 1000km then 7000rpm up to 2500km.
Your risking the integrity of your new engine, it hasn't been run in yet !
07/07 RS4 Avant Mugello Blue
Last edited by matthew.lewis2 on Tue Jul 16, 2013 3:54 pm, edited 1 time in total.
RE: Re: Only 255whp - I have a problem.
Mine and Andy's car generated ~305whp at an AFR of ~12.2 (above 5000rpm) which is richer than yours...ambient temp 22C.
The dyno correction factor suggests difference between 22C and 30C is ~1.5%
Your car seems to be doing whatever Mac4RS's car is doing...
Change out the ECU(s)?
58 C6 RS6 Stage 2+
58 C6 A6 Allroad 2.7 TDi
Previous:
2000 B5 S4 MRC 550 Saloon
2007 B7 RS4 Saloon
1994 S2 Coupe
Previous:
2007 B7 RS4 Saloon
1994 S2 Coupe
- PetrolDave
I hope that Audi M.E. have a better Technical Department than Audi UK have - they seem totally clueless (based on comments on most Audi owners websites and personal experience where they instructed the dealer to replace a sat nav under warranty when the dealer and I could both clearly see that it was the TV tuner that was faulty, so Audi UK picked up a warranty bill for a sat nav AND a TV tuner instead of just a TV tuner - that's £1500 wasted).matthew.lewis2 wrote:I was immediately on the phone to my contact in Audi technical department (not the dealers, but Audi M.E. HQ).
RE: Re: RE: Only 255whp - I have a problem.
PM sent Matt.
Users browsing this forum: No registered users and 164 guests
