Front wipers smearing
Brake fluid change due
Front discs lipped and pads 35% worn
Rear Discs Badly Lipped and Pads worn 35%
Tyre weld out of date
Both near side shockers slightly leaking
Offside front shocker slightly leaking
Anti roll bar colliers cracked
Gear box sump dented
Both front outer cv boots splitting
Antifreeze due at 60K
Spark plugs due at 60K
Slight oil Leak from cam cover gasket
Poly V belt due at 60K (This has been done at 44K so I don't think it needs doing for a while)
Nearside front inner cv boot slightly leaking grease
Vaccum pipe starting to split
Any advice appreciated
HK Fooey
