Just bought S4, couple of minor issues!!
2.7 V6 30v biturbo - 251bhp
2.7 V6 30v biturbo - 261bhp
PretendPorsche
Post by PretendPorsche » Wed Jul 08, 2009 2:11 pm
Hey,
I recently bought a noggy s4, tuned up by mrc, im sure some of you guys would know it.
Anyway, i love the engine, been done really well.
However, i have two problems, firstly the gearchange, which seems to be a common one!!
I wont go into detail about that, as it in g-werks today for pss9s, so i asked them to have a look at it, when they fit them.
Second problem is the brakes!! Again seems to be a common problem, but i have something weird going on, when u brakes gently it almost feels like the pedal is pulsing, it could be warped or cracked discs, but it doesnt really feel like that.
I was reading that the abs often has problems, could this be what im feeling?
Also aside from the current brake set up, i dont feel that the brakes are really that great, so im looking at doing a porsche caliper upgrade, however i can only find people doing it with the 4 pot calipers, has anyone done it with the 6 pot calipers from the gt3??
Nige_RS4
RE: Just bought S4, couple of minor issues!!
Post by Nige_RS4 » Wed Jul 08, 2009 2:54 pm
I think you will need 18" wheels for the 6-pots (the cayenne brakes are a reasonably straight forward fit onto B5 RS4 discs)
The other option (also needing 18's) is the full RS6 (or B7 RS4 brakes).
https://www.speedcams.co.uk
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
Ed 30 Golf DSG - gone
2018 Golf R 7.5
PretendPorsche
Re: RE: Just bought S4, couple of minor issues!!
Post by PretendPorsche » Wed Jul 08, 2009 3:11 pm
Nige_RS4 wrote:I think you will need 18" wheels for the 6-pots (the cayenne brakes are a reasonably straight forward fit onto B5 RS4 discs)
Im currently running 19" bbs ch's, with spacers so there shouldnt be a problem with space to fit them.
I was assuming that the b7 set up would be a good one, but sourcing them seems a pain?
ShaneyB
RE: Re: RE: Just bought S4, couple of minor issues!!
Post by ShaneyB » Wed Jul 08, 2009 3:15 pm
Your spacers could bitted poorly? I had this recently and it felt similar. May be wth checking. What size spacers are they?
Shane
Current
2017 C7 Nardo RS6 Performance
Gone:
C43 AMG Coupe
Black E92 M3
Daytona B7 RS4 Saloon
B6 S4 Saloon Tip
B5 S4 Avant
8L S3
Lexus IS 200
Vauxhall Cavalier 1.8 lsi
Vauxhall Astra 1.6l
Fiat Uno Turbo
Fiat 127 Sport
Ford Cortina MK5
Opel Kadett
ShaneyB
Post by ShaneyB » Wed Jul 08, 2009 3:16 pm
Sorry, could be fitted poorly...
Shane
Current
Gone:
C43 AMG Coupe
Black E92 M3
B6 S4 Saloon Tip
B5 S4 Avant
8L S3
Lexus IS 200
Vauxhall Astra 1.6l
Fiat Uno Turbo
Fiat 127 Sport
Ford Cortina MK5
Opel Kadett
philipwalker
Post by philipwalker » Wed Jul 08, 2009 4:55 pm
The 19" CH`s have less caliper space than the 18" CH`s
18" CH`s 8.5x18 et35mm will fit directly over the B7 set up.
http://www.pwmotorsport.com
PW Motorsport
01437 563929
PretendPorsche
Post by PretendPorsche » Fri Jul 10, 2009 12:06 pm
Ah right, well thats weird hey, i took them off my b5.5 passat, i dont remember the offset but i think its different anyway.
Any ideas where to get a b7 setup or just sit it out and wait for some to come up, my discs are quite bad front and rear so i need to do it asap, and i dont want to spend out on discs twice!
Other thing is, on the rears, can i retain the caliper but just put an a8 disc on there with an a8 bracket, that the best idea?
ogg14
Post by ogg14 » Sun Jul 19, 2009 2:42 am
With the brakes pulsating... Try the rear/front passenger side ABS ring... or hub... Thats what was wrong with mine when i had that problem. The ABS ring was cracked. You will need to replace the whole hub... I think... and its an exchange part.
Andy
grizz
Re: RE: Re: RE: Just bought S4, couple of minor issues!!
Post by grizz » Sun Jul 19, 2009 10:24 am
ogg14 wrote:With the brakes pulsating... Try the rear/front passenger side ABS ring... or hub... Thats what was wrong with mine when i had that problem. The ABS ring was cracked. You will need to replace the whole hub... I think... and its an exchange part.
Andy
It's only a cv joint that goes .Easy fix.
Unit 20
0151 3366888
PretendPorsche
RE: Re: RE: Re: RE: Just bought S4, couple of minor issues!!
Post by PretendPorsche » Mon Jul 20, 2009 10:11 am
Ah ok, so i should get the cv joint checked out?
Whats the talk of the abs sensors not being in right causing a similar problem, is that not correct?
Thanks.
