New VAG-COM user needs a bit of help!
Diagnostic Trouble Codes (DTC) / VCDS (VAG-COM) forum
roi354
Post by roi354 » Tue Jul 14, 2009 3:01 pm
Hi all, my HEX+CAN-USB lead arrived today and so far I've installed everything correctly and plugged into the car. When trying the auto scan, it gets so far (stops at different times) and then chucks out an error that is the same as if it had been unplugged.
Before you ask, I've checked both ends for security and also tried another laptop, all the same.
2ndly, so far the only code I'm getting out before failure is:
1 Fault Found:
17545 - Fuel Trim: Bank 1 (Add): System too Rich
P1137 - 35-10 - - - Intermittent
Readiness: 0000 0000
Can someone suggest the first thing to check please.
Thank you in advance!
Rob
roi354
RE: New VAG-COM user needs a bit of help!
Post by roi354 » Tue Jul 14, 2009 3:06 pm
Ok as far as my fault, I've searched and found some good info to get me going via here and also the ross tech wiki, but still think I might have a problem with the lead?
Nige_RS4
Post by Nige_RS4 » Tue Jul 14, 2009 3:34 pm
You don't say what car this is for, but I would log block 003 and re-post your max MAF output in g/s.
https://www.speedcams.co.uk
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
Ed 30 Golf DSG - gone
2018 Golf R 7.5
roi354
Post by roi354 » Tue Jul 14, 2009 3:39 pm
Sorry! Its a B5 RS4.
Logging might have to wait until I know the lead actally works first.
Keep getting the error:
Interface Status = -2
Interface not ready
PetrolDave
Post by PetrolDave » Tue Jul 14, 2009 5:25 pm
I'm assuming you have the ignition on and that your battery is in good condition or the engine is running?
roi354
Post by roi354 » Wed Jul 15, 2009 8:06 pm
Yes all correct and as it should be. I have now discovered the problem, bizarrely it would appear that the cable doesn't like either my HP or my Packard Bell laptops however its fine with the little Eee PC, go figure???
Work has stopped me from finding the cause of my fault or any further logging but I'll reply here once I have learnt how to use it correctly.
Philws4
Post by Philws4 » Thu Jul 16, 2009 7:22 pm
B5 S4
Return to “DTC / VCDS”
Users browsing this forum: No registered users and 55 guests
