Fitting bilstein's Can you DIY? How hard is it??
spanner1210
- 1st Gear
Hello, Just a quick few question!
How easy is it to fit coilovers to my rs6 saloon?
are there any spec tools i need?
Will i need a ramp?
Is drc easy to take out/blank up??
Thanks in advance for any gen!!
Spanner
Hope you can help
Will i need a ramp?
Spanner
Hope you can help
perthwaRS6
RE: Fitting bilstein
the sticky at the top of the forum is quite easy to follow, I have been told.
i will probably be fitting bilsteins shortly, so can let you know.
I did it myself. It's pretty easy. You can do it with axle stands. You do n't need anything special for the DRC. Just unscrew it from the shocks and blank it off if you want - if you think you might want to put the DRC back on for some strange reason.
The sticky is missing a lot of vital information. It can't remotely be considered a guide.
I've wondered if it brings up any warning lights on the dash when DIY'ing the DRC removal, does this happen or does the car not care it's gone? If it doesn't I'll be doing it myself for sure.
Re: RE: Fitting bilstein
The DRC system on the C5 RS6 is purely mechanical so no warning lights will be shown.DNA540i wrote:I've wondered if it brings up any warning lights on the dash when DIY'ing the DRC removal, does this happen or does the car not care it's gone? If it doesn't I'll be doing it myself for sure.
RE: Re: RE: Fitting bilstein
Yes, but be careful with the height sensing levers which are fragile and shouldn't be removed / unplugged. I had no warning lights at all. Only thing I had was strange vibrations because out of the box the bilsteins are set too low. At least mine were.
One of the questions I had difficulty finding the answer to was what happens when you unscrew the DRC pipes, ie will a pint of hydraulic fluid be injected directly into my bloodstream. In reality, barely a dribble comes out, even on a pressurised circuit.
It turns out that there's some kind of valve which slams shut when you remove the pipe. Presumably to facilitate changing struts.
I had to hacksaw through one of my DRC pipes after rounding the stupid 12mm nut. Once you've sawn it, there's no going back
Felt kinda good, truth be told.
spanner1210
- 1st Gear
Thanks,
Looks like i will be going that way, and considering i'm an engineer on helicopters it should be a doddle!!....Famous last words!!!!
also any good prices for the pss9's??
No offence, but the whole purpose for me when I fitted my Kw V3s in my RS6 was to delete the DRC issues that my car was slowly going to have, and also improve the handling. You can install them coilovers yourself, however I would suggest getting it set and aligned correctly by a suspension specialist. No point fitting coilovers if the car isnt balanced properly, and tyres are not aligned.
spanner1210
- 1st Gear
Re: RE: Re: RE: Fitting bilstein
No offence taken, i would have thought the coilovers would be pretty much bolt on, what sort of adjustment is there in the alignment?? and damping/recoil settings are adjustable anyway? What do you mean by balancing?800088 wrote:No offence, but the whole purpose for me when I fitted my Kw V3s in my RS6 was to delete the DRC issues that my car was slowly going to have, and also improve the handling. You can install them coilovers yourself, however I would suggest getting it set and aligned correctly by a suspension specialist. No point fitting coilovers if the car isnt balanced properly, and tyres are not aligned.
I may be a naive, but i just cant see it being that difficult!!
If im wrong please anyone let me know!!
Cheers, spanner
RE: Re: RE: Re: RE: Fitting bilstein
They are easy. No more difficult than any other and easier than a lot.
As with anything that changes the ride height, you need to ge the tracking / wheel geometry adjusted afterwards. Let the suspension settle for at least a month before doing this though.
Users browsing this forum: No registered users and 110 guests
